560sl auxiliary fan - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-06-2009, 07:59 PM Thread Starter
chestpains's Avatar
Date registered: Dec 2009
Vehicle: 1987 560sl
560sl auxiliary fan
Ok, my auxiliary fan is dead on my 87 560sl... I thought I could pull it out the front but it won't fit. Can anyone tell me how to get it out? Thanks!
chestpains is offline
post #2 of 9 (permalink) Old 12-06-2009, 08:34 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 96 Post(s)
What makes you certain it is dead? So many thing are connected to the operation of it. I will check in the AM but it should come out the front.
rowdie is offline
post #3 of 9 (permalink) Old 12-08-2009, 01:06 PM Thread Starter
chestpains's Avatar
Vehicle: 1987 560sl
My mechanic checked it out for me and told me everything was good to the fan. I can get the parts cheaper than he can so I told him not to fix it. I got the fan and want to put it in myself, but im not sure how to get access to swap them out. my GTO was easier to work on. I could just crawl up in there and work..... things are tighter with German engineering!
post #4 of 9 (permalink) Old 12-08-2009, 01:23 PM
rowdie's Avatar
Quoted: 96 Post(s)
This fan?
rowdie is offline
post #5 of 9 (permalink) Old 12-08-2009, 01:35 PM Thread Starter
chestpains's Avatar
Vehicle: 1987 560sl
Question
yes i removed the black cross member and unscrewed the fan..... thats pretty much where things end. it won't pull out the front... no room. do i have to come up from underneath?
post #6 of 9 (permalink) Old 12-08-2009, 01:55 PM
rowdie's Avatar
Quoted: 96 Post(s)
I went out and looked at my 560 and now have a better understanding of the situation. It does appear it has to come out the front. It can't come out the bottom. They welded the bracket to the cross piece. The plastic cover does come off the top half of the fan assembly. Clipped in three places. The upper brackets are bolted in. Maybe if you removed these things the fan and blades could slip out. The only other thing I could see is removing the fan from the fan motor, then removing the motor. Man did they make it tight in there for such a simple item.
rowdie is offline
post #7 of 9 (permalink) Old 12-08-2009, 02:24 PM Thread Starter
chestpains's Avatar
Vehicle: 1987 560sl
It looks like it will come out that way. I pulled the cross member unhooked the fan and there is no way it will come out that way... i have not tried pulling the fan apart but it just doesn't seem like they would make you pull it apart to install it. Man I'm hoping i don't have to move the radiator!!!!
post #8 of 9 (permalink) Old 12-08-2009, 02:37 PM
dugald's Avatar
Date registered: Dec 2006
Vehicle: 1986 560 SL
Quoted: 607 Post(s)
The manual makes it sound easier...
83-546.pdf
dugald is offline
post #9 of 9 (permalink) Old 12-08-2009, 02:47 PM Thread Starter
chestpains's Avatar
Vehicle: 1987 560sl
Thanks, the fan is as shown in Version 2... i can't get an angle to get it out... not sure why... it's bazar!!
    Auxiliary Fan 1987190E2.6 W201 190-Class 20 04-01-2009 06:08 PM
    Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 11:32 PM
    Auxiliary Fan help dbow2000 W124 E,CE,D,TD Class 1 09-13-2007 01:21 PM
    When should the Auxiliary Fan cooling fan come on? panamacolin W123 E,CE,D,CD,TD,TE Class 22 05-09-2007 07:25 PM
    Which is the Auxiliary fan??? kytrex W201 190-Class 1 07-15-2004 05:41 PM
