1987 560SL - difficulty in getting the sun visor off - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-25-2009, 01:45 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1987 560SL
Need to slide off the passenger sun visir so that I can insert a new male visor clip. I 'm following the directions that Bud's Benz gave me...."Lossen Phillips screw 1 ful turn, Manipulate visor & rod so that they are pointed in the same direction as shown" - no good, the visor will move about a 1/2 inch down the rod and just stop. I called Bud Benz's and they say that Mercedes built in two internal nipples into the sun visor/rod so that they were difficult to steal. He said to put the visor at a 180 degree angle which is the sweet spot for the visor to slide off - no good! I tried 180 degrees up and down and then slowly at all degrees carefully trying to slide the visor and I can't seem to find this sweet spot.
Any ideas or directions, suggestions on what I mat be doing wrong? It seems so simple but I can't get it to slide more than a half inch - need about another 1/2 to clear the indentation so as to be able to slide on the new clip. hgb
Benznewbie1 is offline
post #2 of 9 (permalink) Old 11-25-2009, 03:20 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 164 Post(s)
visor
Seems you are doing it right. Keep fiddling. Your elex wire to the mirror lamp isn't holding you back is it? If so you may have to disconnect.
rocky raccoon is offline
post #3 of 9 (permalink) Old 11-26-2009, 06:16 AM Thread Starter
Vehicle: 1987 560SL
Rocky - thanks for the reply. I'm aware of the wire and keeping my eye on it as I try to remove the visor - if it come to the point where it is preventing the visor from disengaging I will have to disconnect - hgb
post #4 of 9 (permalink) Old 11-26-2009, 08:10 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
Welcome to BenzWorld! I'll slide your query down to the R107 section, where you're far more likely to garner a helpful response from some like-minded enthusiasts. You might also consider completing your user profile, many find that information helpful in regard to providing you with the best possible response.
GeeS is offline
post #5 of 9 (permalink) Old 11-26-2009, 09:01 AM
dugald's Avatar
Date registered: Dec 2006
Vehicle: 1986 560 SL
Quoted: 607 Post(s)
The rod elbow and the visor have to be aligned in the same plane, that is, all lying flat. I suppose that is what Bud's instructions indicate?
You need to pull fairly hard.
You might find things a bit easier to fiddle with if you remove the whole visor assembly off the car.
dugald is online now
post #6 of 9 (permalink) Old 11-26-2009, 10:23 PM
cctoronto's Avatar
Date registered: Jun 2009
Vehicle: 89 R107, 05 CDI
Post
Which leads to my query about the visor, I can't seem to be able to pull the plastic headliner off after I remove the screw that points to the floor at the top of the windscreen... any tricks there?
Hope I explained it clearly enough...
Black Fuzzy Dice Gang Member
cctoronto is offline
post #7 of 9 (permalink) Old 11-27-2009, 05:53 AM
Quoted: 164 Post(s)
for cctoronto
You must remove the rear view mirror.
Grasp mirror stem and give a man-sized tug to left or right. It will snap out since it is held in by a spring-loaded pin. You will not break it so don't be timid. Replacement will be intuitive albeit a little harder to do.
post #8 of 9 (permalink) Old 11-28-2009, 11:26 AM
cctoronto's Avatar
Post
Right, i'll try that!
Thank you...
post #9 of 9 (permalink) Old 12-08-2009, 03:36 PM Thread Starter
Vehicle: 1987 560SL
1987 560SL - getting off the sunvisor
Sorry for this delay in my return reply - laptop died with all my pass words as well. Finally got the visor off and new clip on - thanks to all for their advice! hgb
    Sun visor ScottinSoCal R/C107 SL/SLC Class 7 02-16-2009 06:46 AM
    Need A Sun Visor.. Please Help! socaliguy81 For Sale/Wanted/Trade/Giveaway 1 12-09-2008 04:09 PM
    Anyone need a Sun Visor? RNMB W126 S,SE,SEC,SEL,SD,SDL Class 0 08-03-2005 07:25 PM
    Right Sun Visor GHM For Sale/Wanted/Trade/Giveaway 0 07-28-2005 08:10 PM
    sun visor Guest (MBNZ) W140 S-Class 1 01-24-2002 08:56 AM
