» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-21-2009, 11:56 AM   #1 (permalink)
Date registered: Jun 2009
Vehicle: 1973 Mercedes Benz 450SL AMG
Turn indicators not working
But the hazard flashers do. So I've narrowed it down to the column switch, but this was replaced about 2005/2006 so it's still fairly new. Is it possible that it wore out that fast?
BTW: The flashers worked for about a day before they died, and the hazard switch has been replaced already, so I'm quite sure it's not that.
CMadden is offline   Reply With Quote
Old 11-21-2009, 08:41 PM   #2 (permalink)
Premium Member
Date registered: Sep 2008
Vehicle: 1975 450SL
Premium Member
There is another relay that controls the turn signals. The big trouble is that it hides behind the instrument cluster. Yes, you have to pull the cluster to get to it. To pull the cluster, you have to pull the steering wheel. While you're in there, check and replace any bulbs that may look suspicious. Also check the bolts that hold the pivot for the windshield wipers.
To get the cluster out so you can feel around for the relay, you will have to pull a large electrical connector, a couple small ones, unscrew the speedometer cable and unscrew the line to the oil pressure guage. The oil pressure line needs a small wrench to loosen, 10mm open end IIRC.
This is important:
WHATEVER YOU DO, DO NOT TRY TO START THE ENGINE WITH THE CLUSTER REMOVED.
The oil pressure guage line will immediately spew oil all over the interior of the car. Mainly the driver's seat and floor.
There are a few threads that give detailed info on the process, easily searchable.
Good Luck
RadioTek is offline   Reply With Quote
Old 11-22-2009, 04:48 AM   #3 (permalink)
Premium Member
jplinville's Avatar
Vehicle: 1987 560SL
Premium Member
Send a message via AIM to jplinville
Blinker Fluid [BF-01] - $8.99 : KaleCoAuto, Hard to find automotive items!
Looks like they have sold out...bummer.
1987 560SL Completed 4400 mile round trip in 6 days with only cruise control issues...can you claim the same?
"Once a government is committed to the principle of silencing the voice of opposition, it has only one way to go, and that is down the path of increasingly repressive measures, until it becomes a source of terror to all its citizens and creates a country where everyone lives in fear." - Harry S Truman, August 8, 1950
jplinville is offline   Reply With Quote
Old 11-22-2009, 07:01 AM   #4 (permalink)
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1988 560Sl
Had this happen to me once. Was checking out the emergency flashers (they worked), just because...
Went for a drive, no flashing turn signals. Thought for a moment, switched emergency flashers on-off a couple of times, signal flashers began working again.
Dirty contacts I suspose...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline   Reply With Quote
Old 11-22-2009, 09:12 AM   #5 (permalink)
Premium Member
Vehicle: 1975 450SL
Premium Member
Originally Posted by jplinville View Post
Followed the link... laughed my ass off!!
I gotta get some of this stuff!!
Old 11-22-2009, 09:57 AM   #6 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Sometimes the flasher switch gets caught in between on and off. Maybe someone bumped it or set something on it. Switching it completely on and off will sometimes fix that issue. You can see the relay mentioned above in one of my photos about three quarters of the way down here - https://sites.google.com/site/mercedesstuff/home
Len
'59 220S Cabriolet
'83 240D original owner 347,000 miles
'88 560SL 41,000 miles being parted out-https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 130,500 miles
'03 SLK320 17,000 miles
sokoloff is offline   Reply With Quote
Old 11-22-2009, 09:57 AM   #7 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG
I had forgotton about that one. Need to look at all the products they offer. ATP dispenser is a hoot.
1984 500SL AMG. Lorelei
rowdie is offline   Reply With Quote
Old 11-24-2009, 07:12 AM   #8 (permalink)
So I fiddled with the flasher switch a bunch and flicked the indicator stalk on and off many times and the indicators are still dead in the water. I'm leaning more on the possibility of a faulty switch in the steering column.
Old 11-24-2009, 12:17 PM   #9 (permalink)
rockcrusher's Avatar
Date registered: Nov 2009
Vehicle: 1984 380SL euro
I had a sticky emergency flasher switch, if it doesn't turn off or toggle completely to the off position, the turn signals will not work. Exersice the switch and try the turn signals again. I think some of the PO's cappachino got into there, but that's a whole other story.
rockcrusher is offline   Reply With Quote
Old 11-25-2009, 11:48 AM   #10 (permalink)
ussun's Avatar
Date registered: Jun 2006
Vehicle: 1973 450 SLC AMG, 1995 Chevy Tahoe
I thought the spark PLUGS where the best.available
PS. I can only hope your sl's c's are driving as nice as mine is
Ah that magic feeling of being post mortgage and zero debt. (between repairs)
ussun is online now   Reply With Quote
Left turn indicators are on crack. Booker W210 E-Class 5 07-23-2008 07:40 AM
turn signal indicators/instrument cluster not working. HELP ! cyne wan W126 S,SE,SEC,SEL,SD,SDL Class 0 11-16-2006 07:42 AM
dashboard indicators not working seez90 W126 S,SE,SEC,SEL,SD,SDL Class 0 01-01-2006 04:49 PM
Turn signal indicators Dukming R129 SL Class 11 10-03-2005 04:41 AM
Amber turn indicators and Tailights on ebay matty j G-Class 0 05-09-2004 10:35 PM
