» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-19-2009, 11:05 AM   #1 (permalink)
Date registered: Jun 2009
Vehicle: 91 560 SEL, 77 450 SLC
77 450 SLC Charge Light + Alternator
Hi, Can someone tell me if the is supposed to be power at the small blue wire from the alternator. It has no volts out of it either with ign on or running.
A few weeks ago i replaced the alternator thinking it was faulty. Symptoms were the charge light never came on with the ignition on and the battery went flat.
Seems the alternator was ok but the bulb was blown. I replaced the bulb and all was good for a few days then the charge light went out again. The bulb is ok this time.
The #5 fuse is ok. Is there any relay in the bunch near the fuses that controls the charge light.
There is power to the instrument cluster on 2 terminals. I think 5 and 7 but i could be wrong on those numbers.
Thanks in advance
barranr is offline   Reply With Quote
Old 11-22-2009, 08:03 AM   #2 (permalink)
alternator wire
Can anyone tell me if the small blue wire from the alternator is supposed to have power with ign on or running
Thanks
Old 11-22-2009, 08:07 AM   #3 (permalink)
Premium Member
jplinville's Avatar
Date registered: Sep 2008
Vehicle: 1987 560SL
Premium Member
Send a message via AIM to jplinville
If I'm not mistaken, it's a neg line.
1987 560SL Completed 4400 mile round trip in 6 days with only cruise control issues...can you claim the same?
"Once a government is committed to the principle of silencing the voice of opposition, it has only one way to go, and that is down the path of increasingly repressive measures, until it becomes a source of terror to all its citizens and creates a country where everyone lives in fear." - Harry S Truman, August 8, 1950
jplinville is offline   Reply With Quote
Old 11-28-2009, 04:11 AM   #4 (permalink)
Thanks for the info
1977 MB 450 SLC Battery Light ON "mystery" houtex Vintage Mercedes-Benz 1 06-22-2009 10:10 PM
77 450 slc/ 79 500 slc dtresserd R/C107 SL/SLC Class 2 05-13-2008 01:40 PM
alternator won't charge, dieseljam W124 E,CE,D,TD Class 11 12-11-2007 03:52 PM
w116 alternator no charge airetv W116 S, SE, SEL, SD Class 4 12-05-2007 08:00 PM
Alternator needs a blip of RPM to charge tuttebenne W124 E,CE,D,TD Class 5 12-03-2007 05:15 PM
