» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-18-2009, 04:14 PM   #1 (permalink)
Timing chain again !!!!
I only drive my 380 sl once or twice and then only about 2o miles. After the car has been sitting for 2 or 3 days I hear a rattle at start up for 2 or 3 seconds. The rest of the day when it starts there is no rattle, even some times it does not happen the next day. Am i looking at a problem with the tensioner timing chain or both. The car has 81 k miles on it. It has done this for a long time. The last time a mechanic looked he said it looked ok. About a year ago. He has since retired and moved away. Any ideas out there?
cclake is offline   Reply With Quote
Old 11-18-2009, 04:42 PM   #2 (permalink)
Classic Car Restorer's Avatar
Date registered: Feb 2009
Vehicle: 1985 380sl
I believe that the tensioners are oil pressure sensitive, so If you dont drive the car for a while, you will hear that noise at start up for a second until the oil pressure builds up. When you start the car up multiple times and often, the oil has not bled down yet, so you shouldnt hear anything.
Classic Car Restorer is offline   Reply With Quote
Old 11-18-2009, 04:58 PM   #3 (permalink)
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320
True - but it sound like it happening too much. I think he should get his car back to mechanic Toute Suite, before he wrecks the engine. At least have the chain stretch measured.
My car sits all winter but doesn't make any chain noise on Spring start up.
MBGraham is offline   Reply With Quote
Old 11-18-2009, 04:59 PM   #4 (permalink)
Fotografa's Avatar
Date registered: Sep 2007
Vehicle: 1973 450SL Icon Gold, Black MB-Tex, D-Jet, 3-Sp Auto.
I'd say the issue is with your tensioner.
Life is too short for bad wine or bad cinema.
Fotografa is offline   Reply With Quote
Old 11-18-2009, 05:59 PM   #5 (permalink)
roncallo's Avatar
Date registered: Apr 2005
I would say that the last time your timing chain and rails were changed the tension rail was not replaced. The tension rail is the only rail that actually wears due to the pressure its under. A fully collapsed tensioner and new chain should not allow the chain to hit the head but if the tension rail wears it can hit the head causing the noise you hear.
Oh one other thing. If you never had your rails and oilers changed then change them now. On the 380SL you should do chain and tension rail every 60K miles or 100K if you have a double row chain. Change upper rials and oilers every 10 years whether they need it or not.
To see my 129 parts for sale visit:
http://stores.ebay.com/The-Mercedes-SL-Store
John Roncallo
roncallo is offline   Reply With Quote
Old 11-18-2009, 06:03 PM   #6 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG
I think Foto is correct. I am starting to think that the failure of the tensioner is more responsible than chain stretch or guides. Unless of course a guide breaks.
I wonder if the tensioner failure may be responsible for the guides breaking.
Anyone?
1984 500SL AMG. Lorelei
rowdie is offline   Reply With Quote
Old 11-18-2009, 06:19 PM   #7 (permalink)
roncallo's Avatar
Anyone?
A tensioner has a ball check valve to hold the oil. It cannot be expected for the tensioner to hold this oil forever. It will bleed down after a day or so. The tension rail is often overlooked and not replaced with the chain.
Old 11-18-2009, 06:25 PM   #8 (permalink)
rowdie's Avatar
It also has a spring, at least on the early ones. Couldn't heat, time and contaminates cause the spring to weaken?
Old 11-18-2009, 06:35 PM   #9 (permalink)
roncallo's Avatar
Anything can fail. But IMO the tensioner gets blamed too often. I have never replaced a single one and always cured a morning chain noise with a chain and tension guide rail. I also tried the chain alone when I first got my car and it still rapped in the morning until I replaced the tension rail. I'm at 55,000 miles down the road with that chain and rail replacement and no morning rapping. 155,000 miles total on the tensioner.
Old 11-18-2009, 07:42 PM   #10 (permalink)
rowdie's Avatar
John, just thinking out loud here. I have not delved into the 560 yet. The only ones I have experience with is the early 450's. Both of the ones I had were weak so I replaced it when I rebuilt the engine.
Timing Chain Master Link - will Iwis work on the BECK ARNLEY CHAIN?? xxxbradxxx W123 E,CE,D,CD,TD,TE Class 8 10-17-2009 05:53 AM
Feeding in timing chain, attaching to old chain petecooke W123 E,CE,D,CD,TD,TE Class 4 09-18-2009 10:36 AM
IWIS timing chain compared to JWIS timing chain. ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2008 07:22 PM
Timing Chain or Timing Belt on 230 Kompressor ? Bal W208 CLK Class 0 11-21-2005 01:08 PM
Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
