» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-10-2009, 05:11 PM   #1 (permalink)
Date registered: Nov 2009
Vehicle: 1976 Mercedes 450SL
1976 450SL Purchase
I am purchasing a 1976 450SL with 107,000 miles on it. I know a lot of the repair history of it but forgot to check to see if the timing chain + guides have been replaced. If not at what mileage should this be done?
Also what is the typical cost at a independent import repair shop to replace the timing chain and guides? I am not a DIYer.
The car runs and drives great and I am looking forward to owning it.
Notlad is offline   Reply With Quote
Old 11-10-2009, 05:19 PM   #2 (permalink)
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
With no verifiable history 100k would be considered optimal. Several contributors have had indy jobs done in the $800 +/- range.
isthisdave is offline   Reply With Quote
Old 11-10-2009, 06:15 PM   #3 (permalink)
Fotografa's Avatar
Date registered: Sep 2007
Vehicle: 1973 450SL Icon Gold, Black MB-Tex, D-Jet, 3-Sp Auto.
At that age, the guides should be replaced regardless of mileage, if you are unsure, as they can become brittle with age.
Life is too short for bad wine or bad cinema.
Fotografa is offline   Reply With Quote
Old 11-10-2009, 06:45 PM   #4 (permalink)
Are there any preventive things that should be done in conjunction with the timing chain / guide replacement? Things that would cost less to do simultaneously because a lot of the labor is the same?
Old 11-10-2009, 06:57 PM   #5 (permalink)
isthisdave's Avatar
Camshaft oil tube fittings, cam cover gaskets and crush washers come to mind.
Old 11-10-2009, 06:59 PM   #6 (permalink)
Fotografa's Avatar
Maybe valve stem seals as well, while you are in there.
Old 11-10-2009, 07:44 PM   #7 (permalink)
Thanks everybody for the suggestions and info. I will find out from the current owner later this week if the timing chain and guides have been replaced. He has owned the car for the last 12 years and bought it with 60,000miles on it from a Mercedes dealership.
One other question. I know the car has had the AC compressor replaced and the AC works fine but if there is a problem in the future and it needs freon will I have to convert it to the new R whatever or is freon still available for older cars?
Also what is a good way to know if shocks need to be replaced? It is my first 33 year old car of any kind and my first SL so I don't really know what to expect. When I was looking to buy I also drove an 86 560SL and it seemed to have a better ride (expected after 10 more years of refinement) but ironically enough the 76 actually drove better.
Old 11-10-2009, 07:59 PM   #8 (permalink)
Fotografa's Avatar
The majority of the suspension you your 450SL is the same as the 560SL. (Unless the 560 had SLS). The 560SL had a larger front sway bar, and anti-squat rear-end, but the control arms, trailing arms, subframe and mounts (front and rear) and steering was all the same.
If it were me, I would actually replace all the rubber suspension components and the shocks, unless I could verify that they had been done in the last few years.
Old 11-11-2009, 04:35 PM   #9 (permalink)
The reputable local independent import auot repair guy has quoted me $1050-$1100 to do the following;
-Replace timing chain and guides
-Replace tensioner
-Replace camshaft gears
-Replace crankshaft gears
Old 11-11-2009, 04:42 PM   #10 (permalink)
isthisdave's Avatar
Unless the camshaft gears are showing signs of gross wear replacing them is unnecessary. Replacing the chain, tensioner and its rail, and the upper chain guides as per routine maintenance does not require replacement of the crank gear.
Unless you have issues above and beyond the maintenance aspect those pieces are not needed.
1976 450SL for sale JDR280SL R/C107 SL/SLC Class 0 11-02-2009 04:01 PM
1976 450sl Distributor mtbennett24 R/C107 SL/SLC Class 10 01-22-2009 12:33 PM
1976 450sl dahappybanana R/C107 SL/SLC Class 11 06-07-2006 12:05 AM
looking at 1976 450sl need info mercy76 R/C107 SL/SLC Class 3 06-15-2005 05:57 PM
1976 AMG 450sl Guest (MBNZ) R/C107 SL/SLC Class 0 09-02-2001 04:06 PM
