» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-07-2009, 04:09 AM   #1 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed - The Nobmobile
Trouble Latching the Hood (bonnet)
I'm having trouble getting my hood to latch properly.
Every time I slam it down, it doesn't seem to go far enough to latch.
Anyone have this problem?
Individual parts, even used, are crazy expensive, but if you put them all together into something functional and they're suddenly worth next to nothing. How does that make sense?
nobby is offline   Reply With Quote
Old 11-07-2009, 04:35 AM   #2 (permalink)
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 1978 450SL, 2006 Honda Civic Hybrid, 03 Toyota RAV4
I had that problem years ago, and my dad's car still has that problem. On both, the solution was to make sure the hood release latch was pushed forward all the way before closing the hood. It was sticking, and not allowing the latch to close when the hood came down.
Mine started springing back on it's own after I'd had it a while. My dad's may need a new hood release cable.
When I die, I want to go quietly in my sleep, like Grandpa.
Not screaming, like the people in his car.
Juvenis quod fanaticus nunquam concilio usus quod proditus
ScottinSoCal is offline   Reply With Quote
Old 11-07-2009, 05:42 AM   #3 (permalink)
smack's Avatar
Date registered: Sep 2006
Vehicle: 1973 450SL 1991 420SEL 2008 Jeep Commander
Did you check the little black stoppers on the fender lip? Any reason these would have been moved? I think Scott is spot on with the latch not closing. Clean that mother up and see if it works better.
My Mercedes keep me so broke, I can't even pay attention!!
smack is offline   Reply With Quote
Old 11-07-2009, 06:25 AM   #4 (permalink)
Date registered: Jul 2009
Vehicle: 1972 350SL (4.5L, CA spec)
When I first got my car I had difficulty getting the hood latch to release and I also noticed that one side of the hood was sitting lower. It looked like the hood had been tweaked because the grill didn't line up with the bumper well.
I found that one of the rubber bump stops that Smack mentioned was badly worn, yet the other was perfect. I replaced the bad bump stop, cleaned and lubed the latching mechanism, and with a little trial and error was able to get the hood to line up perfectly. And the latching problem is gone. I don't know if it was an alignment issue or a lubrication issue, because I did them both at the same time.
mgrant is offline   Reply With Quote
Old 11-07-2009, 06:26 AM   #5 (permalink)
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320
I have that problem when I leave tools or nuts & bolts in places they shouldn't be.
MBGraham is offline   Reply With Quote
Old 11-07-2009, 06:48 AM   #6 (permalink)
cctoronto's Avatar
Date registered: Jun 2009
Vehicle: 1989 560SL 172 Anthracite, 265/275 Cream Beige; 24k miles, original
Post
Ouch!!
Penny is her name...
cctoronto is offline   Reply With Quote
Old 11-07-2009, 07:09 AM   #7 (permalink)
nobby's Avatar
Good suggestions.
I will take a look.
Old 11-07-2009, 08:21 AM   #8 (permalink)
nobby's Avatar
I think I got the thing figured out.
It's the SOHK.
I checked the build sheet and it's not listed.
So off it comes.
Old 11-07-2009, 08:52 AM   #9 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG
Stupid Owners Hard Knobby?
1984 500SL AMG. Lorelei
rowdie is online now   Reply With Quote
Old 11-07-2009, 09:39 AM   #10 (permalink)
MBGraham's Avatar
Shit Only Happens to Knobby?
Bonnet / hood stuck chinaldino W211 E-Class 1 01-18-2009 11:07 AM
Hood....Bonnet.... CA-B200 W245 B-Class 18 03-26-2008 03:33 PM
bonnet(hood) woodwork1 W203 C-Class 1 10-24-2007 10:51 AM
bonnet(hood) woodwork1 W203 C-Class 0 10-24-2007 10:47 AM
SEC Hood (Bonnet) on a SE/L Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 04-25-2002 10:32 AM
