I'm doing some detailing on my new 86 560 SL, and when I took the hardtop off for the first time, I noticed that the strip of metal ( 2- 3 inches wide ) that goes across the car at the top of the windshield ( where the front locking pin holes are located ) could use a little shining up. It is not as shiny as the chrome trim around the windshield and the rest of the car, so I'm not sure if it's chrome or aluminum. Some cleaners are meant for chrome, and some for aluminum, and the Mothers metal polish I have has a note on it that it is not recommended for chrome.
Does anyone know if this strip is aluminum or chrome ?
Also, a tip I found on another site for removing rust from chrome is to use aluminum foil soaked in water and rubbed on the rusted spot. I had a very small amount of surface rust between the MB Tex trim and the edge of the metal strip referenced above and tried the aluminum foil tip, and it worked ! Not sure why it works, but it took the rust off very easily.
