High Idle on '89 560 SL - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-13-2009, 04:18 PM Thread Starter
Date registered: Jul 2009
Car won't settle down after idling or running. Let me back up and tell you what happened before the car started doing this. Battery was dead and had it jumped. Friendly passer by connected the wrong terminals. I put new battery in and seems like there must be a constant drain, wont hold a charge. Now it idles @1,500 rpm and won't kick down even after warming up.
Where do I start?
refiguy is offline
post #2 of 6 (permalink) Old 07-13-2009, 04:51 PM
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
Quoted: 17 Post(s)
Praying that your computer isn't fried is a good place to start.
Then I'd move on to the OVP relay, and hope that's what got damaged.
When I die, I want to go quietly in my sleep, like Grandpa.
Not screaming, like the people in his car.
Juvenis quod fanaticus nunquam concilio usus quod proditus
ScottinSoCal is offline
post #3 of 6 (permalink) Old 07-13-2009, 07:09 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Another possibility is blown short diodes in the alternator. Reverse polarity at the currents typical in primary automotive systems can be a Very Bad Thing(tm).
I think I'm going to have to finish writing the howto on auto electrical troubleshooting that's been kicking around in the back of my head.
Good Luck. May whatever got blown be cheap. For Mercedes levels of cheap, of course.
Scott
RadioTek is offline
post #4 of 6 (permalink) Old 07-14-2009, 04:47 AM
Date registered: Nov 2008
Vehicle: 1988 SL560, 1989 560 SEL
WOW !!!!! Scares me and I ain't afraid of nuthin'
rondor2 is offline
post #5 of 6 (permalink) Old 07-14-2009, 06:32 AM Thread Starter
Question
Thank you for the input. Where do I find the OVP relay?
In addtion is there a way to test the Alt.?
I put a meter on the battery while the car is running and it appears that the Alt. is charging the battery (even though it won't hold a charge now on a brand new battery, yikes).
refiguy is offline
post #6 of 6 (permalink) Old 07-14-2009, 12:54 PM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
On my car when it did that, it turned out that the throttle position sensor went bad. It is mounted deep in the V of the engine on the butterfly shaft. It can easily be checked as the connection is at the top left front of the engine. There are three wires: common, full closed idle, and full open throttle. At idle, there should be continuity between the common and idle wires. At full throttle, there is continuity between the common and full throttle wires. My sensor went bad in the idle circuit and the engine would not idle down. Hopefully that is your problem as it was not all that expensive to fix, just a pain to get to.
KCM is offline
    560 SEC - High Idle RMasters W126 S,SE,SEC,SEL,SD,SDL Class 15 08-01-2012 09:06 AM
    Took the 560 to dealer today for high idle NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 13 10-12-2004 07:52 PM
    High speed vibration from my high price 560. cyrusthefool W126 S,SE,SEC,SEL,SD,SDL Class 8 09-04-2004 04:24 PM
    High idle after hosing down engine compartment on 89 560 SEL TBonus W126 S,SE,SEC,SEL,SD,SDL Class 12 02-25-2004 04:15 AM
    How high does your 560 idle? SheepAlert W126 S,SE,SEC,SEL,SD,SDL Class 2 04-12-2003 03:32 AM
