NLA Mercedes Parts Remanufacture Request
NLA Parts Remanufacture Request | Mercedes-Benz Forum (benzworld.org)
Open MB Service Campaigns
C/R107 Front Sub-Frame Recall Information by isthisdave
Throttle Linkage Component Replacement by Cookie79
Service Literature
107 service manual by sokoloff
Online downloadable version of the MB-USA Service Manual CD
Service Literature by isthisdave
MBUSA Classic Center Technical and Service Literature ***
Factory Approved Service Products August 2007 *** Over 20 pages of approved liquids, pastes and lubes, etc for your 107 (and other M-B products)
Model 107 Maintenance Manual Index (tonk.ca)
Model 107 (startekinfo.com)
Mileage
High Mileage Award by nobby Everything you want to know about obtaining and installing your own grille badge.
For Sale or Want To Buy
Found this 107 on Craigslist/Ebay/etc, the BW107 For Sale and WTB Thread
Buyer Checklist Thread by JN74SL
Moving / Shipping A Car
Caution!
Safely working under the car by mach4
00) General Technical Data
50th anniversary: 107 Production Numbers | Mercedes-Benz Forum (benzworld.org) ADDED May 6, 2021
MB-USA Model 107 Service Manual Library***
MB-USA Classic Center, Irvine CA
MB-Europe Classic Center***
MB-USA Electronic Parts Catalog (EPC) (Not Mac compatible)
Mercedes VIN Decoder | Decode Your Mercedes-Benz VIN (lastvin.com)
SL Registry (sl-registry.com)
Interesting links for the 107 by Digmenow
Year and Mileage...Please by nobby
Insurance call out of the blue by ScottinSoCal
Recommended Repair Shops A BW board for listing or seeking repair shop recommendations
Components Locations Acronyms Pics by isthisdave(C.L.A.P.)
Mercedes-Benz SLC 107 series versions & types*** Specifications, Technical, and Performance Data
Mercedes-Benz SL 107 series versions & types*** Specifications, Technical, and Performance Data
** The Tool Loan Program**
Bolt Grade Markings and Strength Chart by reno4u2 ***
Parts Vendor Quality List ***
Guide to Mercedes Benz Vehicle Data Card Codes and Meanings by ricebubbles (W220 Forum)
MY 1979 - 1989 North America SL Owner's Manual PDF by ath20wj
01) Engine Block Assembly
03) Crankshaft
Oil Seals by cushjbc
05) Engine Timing, Valves
The Truth About Timing Chain Failures? by daveward
450 - M117 Timing Chain Replacement***
Timing Chain: A Visual Inspection by nobby
Timing Chain Slack and Cam Gear Replacement Question by maynardg
M110 Valve Adjustment by nobby
TIMING CHAIN, guide rail, tensioner, sprocket, pin puller VIDEO now streaming by PanzerPuff
Installation of 380 SL timing chain tensioner by Aussiemerc
07.3) Bosch K-Jetronic CIS Fuel Injection
Bosch D-Jetronic and K-Jetronic CIS Troubleshooting by Nutz 4 Benz courtesy of the W116 board
Bosch K-Jetronic CIS Overview by isthisdave
Bosch KE-Jetronic Overview by isthisdave
K-Jetronic Fuel Distributor Control Plunger and Diaphragm Pictures by cptbd (post #8)
CIS Fuel Injection Compilation of Data by romankrzy
Fuel System Service Procedure by BenzHacker
First Time attempt to check CIS pressures by Tony Barroso
K-Jet Fuel Volume Test Procedure by ctaylor738
Finally made my decision Finally made my decision by Pex
87 560SL KE Jetronic Fuel System Problems by RacerRich
K-Jetronic WITH Lambda Overview and Adjustment by Myndex
KE-Jetronic Lambda control (duty cycle check & adjustment) | Mercedes-Benz Forum (benzworld.org)
WUR IDENDITY PDF Auxiliary Air Valve Overhaul - AAV | Mercedes-Benz Forum (benzworld.org)
07.4) Bosch D-Jetronic Fuel Injection
Who rebuilds Djet components - Develop a BW list? | Mercedes-Benz Forum (benzworld.org)
Post #6 of Throttle Position Switch - Early D-Jets. by MBGraham
Pressure sensor adjustment by 450slcpilot with assist by MBGraham
MB Technical Data Manual Carbon Monoxide Specifications by lfedje
Auxilliary Air Valve/Air Slide Valve Deconstructed by rowdie
AAV? by brad131a4
couple cruise in pics and vaporlock question. by 1972SL350 (D-Jet Hot Start Vapor Lock)
The Comprehensive Illustrated Djet fuel injection system (72-75 350-450SL) Thread by The Proctologist
Early Mercedes Bosch D-Jetronic Training Manual(Download)
Bosch Manifold Pressure Sensor Disassembly | Mercedes-Benz Forum (benzworld.org) ADDED May 4, 2021
07.5) Ignition System, Bosch D-Jetronic Fuel Injection*
Distributor Removal & Repair by MBGraham
PETRONIX and Other Electronic Ignition Conversion Threads | Mercedes-Benz Forum (benzworld.org)
D-Jetronic Trigger Points (Pulse Generator) Rebuild | Mercedes-Benz Forum (benzworld.org) ADDED NOV 2021
* See Section 15 for post 1985 cars equipped with either Bosch K or KE equipped ignition sytems
09) Air Cleaner Assembly
13) V-Belts
14) Intake and Exhaust Manifolds
The Encyclopaedia Germanica Volume 107
Service Literature
Mileage
Caution!
Engine Assembly & Engine Management
(The EGv107 numbering system mirrors both the printed
MB Field Service Manual and the MB-USA Online Manual in sokoloff's link above)
03) Crankshaft
AAV? by brad131a4
13) V-Belts
Nominate an Engine Assembly & Engine Management thread This link leads to an open thread for nominating a worthy thread for inclusion.
