86 560SL How to remove outside temp gauge? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-15-2009, 08:59 AM Thread Starter
Date registered: Mar 2008
Vehicle: 1995 325IC and 1986 560SL
Send a message via MSN to ttnguyen23
Hi all,
During reomoving for cleaning the instrmument cluster. I failed to remove the outside temp gauge?
Any advice?
Thanks
ttnguyen23 is offline
post #2 of 8 (permalink) Old 03-15-2009, 10:08 PM
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
Quoted: 52 Post(s)
It sits in a round gasket and you either have to remove the radio or the glove box to get your hand in there to push it out.
Don't even THINK of trying to pry it out from the front.
Unless it is broken or not lit, you can clean it without the trouble of removing it. If you want to repaint the needle or replace the bulb, be aware that it is almost impossible to disassemble. Almost
_________________________
Homebrew MB First Gear Start!
http://juliepalooza.8m.com/sl/mercedes.htm
strife2 is offline
post #3 of 8 (permalink) Old 03-15-2009, 10:33 PM Thread Starter
When I remove the cluster out. I try to reach my hand toward the back of the outside temp gauge and try to push from back toward the front. These gasket around the gauge is so tight. Unfortually I can not put it out.
I just need to take it out and clean the lens. It looks dirty and have to see.
I have the aftermaket radio installed in the car when I bought it.
One time I try to remove but it is hard to get it out.
I guess the close it one the temp gauge is the radio. I will try to remove the radio again.
You are sure just push in back the gauge it will comes out. No bracket or screws involved. Correct?
Thanks
Thanks
post #4 of 8 (permalink) Old 03-15-2009, 10:55 PM
strife2's Avatar
Quoted: 52 Post(s)
Thanks
Thanks
On my 85 and 86, the round temp gauge in the middle of the dash is in a round rubber gasket, and it pushes out. there was no bracket just the connector and cable that provides power for the electronics, lighting, and the wire for the temp sensor (4 pins total). MAybe some silicone spray or liquid soap would help.
Again, the outside of the lens can be cleaned spotless with the usual methods without removing the gauge; it's made of glass so scratching is not a high concern.
If the INSIDE of the glass is dirty, it would require disassembly, and again, this is EXTREMELY difficult because it was not meant to be disassembled. Frankly, unless you are very good with this stuff I wouldn't try it - but this is how it was done:
Center Temp Gauge (107) Restoration - ShopForum
strife2 is offline
post #5 of 8 (permalink) Old 03-15-2009, 11:23 PM Thread Starter
Angry
On my 85 and 86, the round temp gauge in the middle of the dash is in a round rubber gasket, and it pushes out. there was no bracket just the connector and cable that provides power for the electronics, lighting, and the wire for the temp sensor (4 pins total). Maybe some silicone spray or liquid soap would help.
After I read your explanation. it seem to be hard to remove the front glass lens. My gauge is dusty inside and it need to remove the front glass to clean.
I guess I will think twice now.
post #6 of 8 (permalink) Old 03-16-2009, 09:42 PM
strife2's Avatar
Quoted: 52 Post(s)
Hmmm....the gauge really seemed to be sealed pretty well (there's even a gasket at the rear where the connector prongs stick out). I wonder how yours got so dirty. Maybe a previous owner smoked a lot in the car?
strife2 is offline
post #7 of 8 (permalink) Old 03-16-2009, 10:04 PM
Date registered: Sep 2006
Dad gum aftermarket radios. The bain of consoles everywhere.
I'm just a singer in my own mind.
BenzToy is offline
post #8 of 8 (permalink) Old 03-16-2009, 10:15 PM Thread Starter
I wonder about it too. How can the dust get inside?
108 cdi temp fan / temp gauge problems merc 108cdi V-Class 5 07-01-2007 04:16 AM
Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 09:03 AM
outside temp gauge bigboy338 W210 E-Class 0 09-28-2005 09:04 AM
Temp Gauge dahappybanana W124 E,CE,D,TD Class 2 08-01-2005 07:32 PM
When outside temp is higher than 40', how come the temp gauge still shows 40'? noelb W163 M-Class 5 04-16-2002 01:43 PM
