560SL Transmission Clunking - Worried!! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-01-2008, 06:38 AM Thread Starter
Fiorano's Avatar
Date registered: Feb 2008
Vehicle: 1989 Mercedes 560SL, 1989 Euro Mercedes 300SL, Volvo C70, 2004 Discovery, 1997 Mercedes SL500
My 560SL has developed some worrying clunking Let me explain :
When i engage Drive, the transmission engages with a clunk after about 2 seconds with a bit of a pull on the vehicle. If i then shift to reverse, there is a worrying creaking noise and another clunk. It does not sound healthy at all. A few days ago, it would not go into reverese at all and eventually after 10 tries from D to R, it eventually did. At the times it was not engaging reverse, it was making a whining noise.
Also, quite regularly, it will not engage when i put it in D. I have to select 3rd gear then put it in D for the transmission to engage.
Any ideas as to what the problems could be?
Oh, and its a 1989 model with 72k on the clock.
Cheers - Max
Fiorano is offline
post #2 of 6 (permalink) Old 10-01-2008, 06:51 AM
A&L's300SL's Avatar
Date registered: Apr 2006
Vehicle: 87 300SL "Roadster" 86 420SEL "Limo" 89 420SEL The "New" Limo 87 190E 2.6 fact bodykit
First of, check the oil level in the tranny.
My auto in my SEL had a similar problem although maybe not quite as bad, so I had it serviced and the modulator adjusted and now it's a hell of a lot better.
Good luck with it Max
Andrew
"That's the way I like it baby, I don't want to live forever"- Lemmy
A&L's300SL is offline
post #3 of 6 (permalink) Old 10-01-2008, 10:18 AM
daryn's Avatar
Date registered: Nov 2004
Vehicle: 1978 280slc
Quoted: 40 Post(s)
What about the shifter bushing Dugald was talking about? Rule out the small stuff b/f the big stuff.
Ich brauch Geld fur Gasolin, explosiv wie Kerosin, mit viel Octan und frei von Blei- Gib mir Benzin!
daryn is offline
post #4 of 6 (permalink) Old 10-02-2008, 02:40 AM Thread Starter
Fiorano's Avatar
Thanks guys for your help.
I think i've located the culprit . . . .i checked under the tranny and both shifter bushes are . . . . missing!!
Thanks again - Max
Fiorano is offline
post #5 of 6 (permalink) Old 10-02-2008, 03:22 AM
Date registered: Jan 2007
Vehicle: Too Many
Quoted: 139 Post(s)
Cheers - Max
1. check fluid level, with engine running, warm, in 'P' on a level surface.
2. note colour of fluid. (should be nice clean light reddish brown if genuine fluid, or just red if dex 2/3.
3. modulator pressure needs to be checked with a vacuum gauge.
4. modulator adjustment needs to be done with engine cool, or you will get burned.
5. there are't too many things to go wrong: clutch packs, bands and servo piston are the usual culprits. correct adjustment and regular fluid changes ensure longeivity (service (oil and filter plus new pan gasket every 30,000km)
6. if you do this, and you still have problems, then chances are the bands are cactus. the seal on the servo piston is usually not far behind. some transmission conditioner can relieve a bit of stress, and soften up seals a bit to make them pliable, but it is not a guarantee and only delays the inevitable.
overhaul is not cheap, but is worth it, and should give you another 200,000+ km of trouble-free motoring.
Current Drivers:
1987 107.048 Stella /// 1987 201.034 Hermann /// 1992 124.051 Gretel /// 1991 Range Rover Vogue SE Oswald /// 2012 RenaultSport MeganeRS Trophy 8:08 Jean Rédélé
OZBENZ - Australian Mercedes-Benz Forums <-Click
JoeB is offline
post #6 of 6 (permalink) Old 10-03-2008, 01:56 AM Thread Starter
Fiorano's Avatar
Thanks a bunch Joe for your guidance. I'll fit the bushes in then arrange at some point to carry out your recommendations.
Cheers ! - Max
Fiorano is offline
Transmission flaring or clunking? VCV DIY Gregs300CD W123 E,CE,D,CD,TD,TE Class 17 08-26-2015 02:51 PM
Clunking (loose) transmission selector? stiminski C208/A208 CLK-Class 4 08-29-2009 01:54 PM
86 560SL Leaking the transmission fluid ttnguyen23 R/C107 SL/SLC Class 6 04-21-2008 03:19 PM
"Clunking" noise from transmission wmedia W140 S-Class 0 08-16-2005 01:13 AM
Occasional Clunking from underbody... Transmission or... doberman97 W163 M-Class 3 07-30-2003 06:10 AM
