560SL Manual transmission conversion, Crank position sensor Help? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 07-18-2008, 06:33 PM Thread Starter
Date registered: Apr 2008
Vehicle: Mercedes 1980 6.9 Euro Mercedes 1984 190E Euro 3.2 24v M104 Project Mercedes 1985 500SEC Euro soon t
Hello everyone. I am Converting a 1986 560SL to a manual 4 speed transmission from a 350SL, I've researched alot of forums in the past people wanting to convert a new m117 or m116 aluminum block to a manual trans but the problem is always that the iron block motors like the 350 had a removable plate that the aluminum motors don't have. I have solved this problem but for my research and testing I had been using a Aluminum m116 380 and 500 Euro engine. Witch it would work fine on either of those motors but i decided to put it in my 560SL. And ran into a unforeseen problem.
The first problem is that Unlike the 380 and 500 engine the CPS sensor is on the rear drivers side head above the flywheel. This wont work when i change the fly wheel and housing. And it will have to be moved or eliminated.
the only options ive come up with so far, are
1 Change the distributer with one from a 380 or 500 engine and change the ignition system.
Or 2 move the sensor some where else, but where and how?
Or 3 eliminate the sensor, How can i make it run with out it?
Any suggestions and help would be great, thanks!
I'm 2 days into my conversion and if anyone is interested I will post pictures and my progress of my conversion
Actave is offline
post #2 of 16 (permalink) Old 07-19-2008, 11:36 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1491 Post(s)
Of course. It will also help legitimize your request.......... as you are a very new member.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #3 of 16 (permalink) Old 07-20-2008, 04:45 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
Why cant you use the front mounted 380/500 CPS is it not compatible? Definitely post pictures and part numbers. I've often thought of doing this.
roncallo is offline
post #4 of 16 (permalink) Old 07-20-2008, 04:59 AM
Date registered: Sep 2006
Bastiges. I've got a sawzall. He. He. He.
I'm just a singer in my own mind.
BenzToy is offline
post #5 of 16 (permalink) Old 07-20-2008, 05:12 AM
Always Remembered RIP
ussun's Avatar
Date registered: Jun 2006
Vehicle: 1973 450 SLC AMG, 1995 Chevy Tahoe
Are you starting with all the parts at hand or are you getting as you go. I'm guessing it's all used parts. I talked to a parts guy about doing a 5speed into a 450 and when he started getting to $9000.00. I started asking about something else.
I hope your not doing it all to smoke the rear wheels. We all understand the SL's auto tranny stops that pretty much.
Plus pics of the whole thing would be great.
PS Try not to bother Roncallo to much, he's got his own little project to finish up Back to work John.
ussun is offline
post #6 of 16 (permalink) Old 07-20-2008, 05:18 AM
Go look for ....... doors ussun.
BenzToy is offline
post #7 of 16 (permalink) Old 07-20-2008, 10:31 AM
roncallo's Avatar
Quoted: 295 Post(s)
Damn
He caught me screwing off again. It's hot out there ya know.
roncallo is offline
post #8 of 16 (permalink) Old 07-20-2008, 07:41 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
Why can't you make the sensor work with the new flywheel? IIRC, you would need to remove teeth to create notches for the sensor to read.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #9 of 16 (permalink) Old 08-04-2008, 09:58 PM Thread Starter
Ok, sorry for my lack of keeping up with this thread I didnt think i was going to get any response after the first few days. Anyway. I have preceded with my conversion. and the engine is now in the car with the 4 speed manual. It runs. I haven't had a drive shaft made yet. It needs to be much longer. And i need to hook up the clutch lines and shift linkage.
I solved the CPS sensor problem by using a M117 500 euro engine distributor.
The engine will start but will not run smooth. I think i might still be having timing problems. As well as alot of wiring problems as most of the connectors have fallen off or have damaged wires. on the engine harness.
I will be posting more pictures and info soon.
So my current problems i am addressing are. the spark timing, I have hooked up the CPS lead from the distributor to the orginal system. I set the cam to TDC mark. and pully mark to #1 set distributor at #1 mark. it is hard starting and runs very rough, Does this sound like a timing problem?
as i mentioned before the wires to the cis, throttle body, sensors etc are very messed up so those will have to be sorted with.
Actave is offline
post #10 of 16 (permalink) Old 08-04-2008, 10:34 PM Thread Starter
Transmission and plate test mounted on M116 380 Block:
Plate, Flywheel, clutch and pressure plate mounted on m117 560SL engine.
Most parts were from a 350SL, the hub on the crank of the motor had a pin in it for lining up the auto flywheel that had to be drilled and removed also, The 560 had a rear crank shaft positioning sensor that had to be removed and replaced with earlier distributor that has the sensor on it.
4 Speed 350SL manual Mounted and ready to go: The transmission did not bolt directly up, the plate had to be modified and mounting had to be changed. how ever some of the main bolts did line up.
Reinstalled original engine in 1986 560SL with 500SEL euro distributor, and 350SL manual transmission.
Clutch pedals and shifter installed:
Pedal cluster required little modification, Drilling and expanding the mounting bolt holes. Cluster is from a 240D, The sifter is from a 190E it required no mods. but shift pattern and linkage movement is probably going to be a problem and I may use its parts to repair and use the 240D 4 speed shifter.
Actave is offline
    Crank Position Sensor dannydang W220 S-Class 46 02-15-2014 07:26 AM
    Crank Position Sensor 190benzo26sc W124 E,CE,D,TD Class 13 07-31-2012 04:50 PM
    crank angle sensor or crank position sensor Gwagensofli G-Class 1 07-31-2007 04:37 PM
    Crank position sensor, where is it? starscream W140 S-Class 3 10-03-2006 08:55 AM
    Where is the Crank Position sensor? Ben Kokes R170 SLK-Class 2 05-10-2002 06:26 PM
