» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 07-02-2008, 02:42 AM   #1 (permalink)
mxcrasher's Avatar
Date registered: May 2008
Vehicle: 81 380 SL. 98 lexus GS 300 2000 Toy tundra
Question Is there a way?
81 380sl can anyone tell me a way to test the OVP and the idle control relays before I throw some money at them???
thank you all for the support that this site gives!
mxcrasher is offline   Reply With Quote
Old 07-02-2008, 04:46 AM   #2 (permalink)
Date registered: Jul 2007
Vehicle: 1981, 380 SLC - US model
Look at the photo.
1. Find idle module under the dash (passenger site)
2. Detach connector at idle control module
3. Switch on ignition
4. Test voltage at pin 2 and 4
I had no voltage between pin 2 and 4.
After changing OVP relay - voltage was back and engine worked fine
mbenzfan79 is offline   Reply With Quote
Old 07-02-2008, 08:15 AM   #3 (permalink)
mxcrasher's Avatar
So I guess that it either works or it does not??? I have no power at those pins. As I can tell by the wire diagrams that the Idle control relay is powered by the OVP relay. That is why I wanted to test them both...thanx for the info
Old 07-02-2008, 10:59 PM   #4 (permalink)
If there is no power at pin 2 and 4 -> idle module does not work and aux idle valve does not work either. That is the reason for your low power problem.
New OVP relay costs around $60.
Please report, if new OVP relay solves your problem.
