» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 05-09-2008, 05:36 PM   #11 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed
Originally Posted by NormanB View Post
Rob that is nice history to know about your vehicle. Thanks for taking the time to share.
That is a nice story. Congrats.
Is it me, or did you neglect to say what the 4 th owner paid for it in 2008 dollars?
Originally Posted by Dr.Dave View Post
Dude! It is what it is....
nobby is offline   Reply With Quote
Old 05-09-2008, 06:21 PM   #12 (permalink)
Date registered: Nov 2006
Vehicle: 73 450SL
[quote=nobby;
Is it me, or did you neglect to say what the 4 th owner paid for it in 2008 dollars?[/QUOTE]
I do believe you're right...so do tell...do tell.
NormanB is offline   Reply With Quote
Old 05-09-2008, 08:32 PM   #13 (permalink)
Date registered: Jun 2007
Vehicle: 1967 250sl "California" 1972 350sl #60
Very nice car. Is it one of the first 500 produced?
hilld is offline   Reply With Quote
Old 05-10-2008, 02:59 AM   #14 (permalink)
Date registered: Jun 2004
It's actually a 450SL.. :-)
As posted previously,to get around a piece of legislation the cars were sold in the USA only as 350's. To still have the badge tells me the car has been well looked after. The rubber under coat ,under the car, is PVC and has been used by Mercedes since 1959. Great stuff if it's OK.
I love the looks of a black SL ,what color folding top does it have?. If it matches the interior it will be stunning looking with it erected.
The 'metal plate thing' was used by dealers in the 70's in much the same way as those old credit card imprinters used to work. The plate was inserted in a machine and used to enter service work done on the car. Somewhere ,there will be detailed records of all dealer work done on that car and you can request a copy of it from your local Daimler AG affiliated Workshop.
You wont fiod that for a Mustang... :-))
Slow trans takeup is a symptom if old age with those trans i'm affraid. Get it serviced and add some Lucas ( or similar) trans treatment and it will last OK for another 30 years. Check the trans linkage to make sure the two nylon bushes are still OK.
The small is probably a sign it's running to rich,possibly a leaking cold start injector which will also explain the lumpy idle. these cars smooth from cold start with idle at 1500 rpm slowing to 750-800RPM when the engine reaches running temp.
Another really important thing to remember is to replace every single peice of rubber in the fuel system from the tank forward.. More than one Djet equipped merc has burnt down because of rotten fuel lines bursting under pressure.
mercmad6.3 is offline   Reply With Quote
Old 05-14-2008, 10:06 AM   #15 (permalink)
ConorD's Avatar
Vehicle: '72 350 SL
Hi Rob - late to the party but welcome!
350SLs rule - it's always good to be younger than your car.
Originally Posted by 1972-350SL View Post
2. Under the rear carpet there is insulation with shiny layer on top but no rust under neath the car. Sort of like whats under aluminum siding. Is this normal?
I have the same under my 350's carpets.
4. The car when it first starts up from cold it revs from 1500rpms to 1000rpms to 1500rpms to 1000rpms every 2 second for about 1 minute and then it stays at 1500rpms and works it way down to 800rpms. After its warm its fine. Is this normal? (It did not do that when I first looked at the car but I did add Fuel System cleaner to the gas tank and thats when the problem seemed to start.)
Mine does the same thing. I talked to the PO about this, and they had gone to the trouble of writing to MB about the issue (they are MB nuts). I have the letter back from MB in my history file which points to a problem with the "warm up air slide". Now I have no idea if this is the case - but hey, that's what they said! I'm used to it now and don't let it bother me.
Enjoy - it looks like a great car.
Conor
1972 350SL (Euro/ROTW)
ConorD is offline   Reply With Quote
New Owner Questions ivancook W202 C36 AMG, C43 AMG 1 02-13-2007 08:58 PM
New owner...questions... Zonald W208 CLK Class 7 09-11-2005 10:55 PM
new owner, 2 questions tom_d W126 S,SE,SEC,SEL,SD,SDL Class 2 06-16-2005 12:45 PM
New Ml Owner some questions... Buddhatikkigod W163 M-Class 3 10-28-2002 11:06 PM
New owner -two questions about the ML CaliBNZ W163 M-Class 17 05-22-2002 11:43 PM
