Originally Posted by w107w123w210 If you search the net, you will find dozens of posts suggesting that we stay away from platinum plugs for these cars and just a few in favour. Here is one link: http://mbca.cartama.net/showthread.php?t=14591 My view is that there is no reason to use anything different from the wires and plugs Mercedes specified, which means use Beru wires and non resistor plugs like W7DC or NGK equivalent. Those resistor wires don't fail - the one link is just trying to sell another product. I changed my OE wires after 35 years just because I thought I should Unfortunately, I bought the Bosch wirees before I did any research - sems OP is going down same path  |
Thanks for the link.
Just remember, your experience is just one data point.
I just read it, and Bill did not have a technical reason to back himself up as to why someone should avoid Platinum plugs except for the fact that the electrode may fall off. You need to also pay special attention to the design of the Platinum Plus plugs. These are not the Platinum+4's nor the Iridium+4's. And I can understand as to why Bosch didn't recommend them. The Platinum+4's gaps cannot re-gapped and the gaps are quite large.
How many cases have you heard of spark plugs coming apart inside a naturally aspirated engine under normal usage (ie. not racing). And why only for Platinum plugs.
Bill say he was more worried about cheap platinum plugs. Basically, he was back-peddling. Tell me which one is a cheap platinum plug. If you have the technical expertise and the interest, closely examine some of the modern spark plugs as to their design, construction, material, and quality control. Upon looking at the design of the Platinum Plus plugs, I see no reason as to why this plug is prone to self destruction inside the combustion chamber. Also, we are cleared that we are talking about naturally aspirated engines, right?
If you can provide a link where somebody had tried the combination recommended by Bosch and have failed, then it would tweak some interest. For now, Bosch's expertise sounds more comforting than Bill's opinions. As I clearly stated above, you need to change both the wires and plugs at the same time.
If somebody can provide a technical reason as to why these engines are so aversive to platinum plugs and Bosch wires, I would be very thankful. Incidentally, Bosch does offer copper plugs too, but I cannot justify using copper plugs in 2008. It doesn't make sense. Personally, I would use Iridium's but than the OP didn't say he wanted to be a tinker or pioneer.
I used Google a little more, and somebody claims that they found that platinum plugs can get fouled easier (unfortunately he doesn't specify the plug). This I can understand if they didn't changed the wires too. Most spark plugs today are resistor suppressed. In addition, the center electrode is much smaller. If the rest of the ignition system does not compensate, there could be problems. Bosch offers a new wire set and recommends a gap. I don't see an issue.
