Noise in Passenger Side Panel Area - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 12-16-2007, 06:25 PM Thread Starter
cookie79's Avatar
Vehicle: 1979 450 SL
Originally Posted by HalVaughan View Post
Muskrats.
Definitely angry muskrats.
No don't think its muscrats. Haven't seen them on the property. Can't be the cow, deer, fox, ferral hogs or turkeys that cross the property they are too big. I guess it could be an angry scorpion, or tatrantula.
Tom
cookie79 is offline
post #12 of 27 (permalink) Old 12-16-2007, 06:29 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 92 Post(s)
I'll vouch for the angry scorpion. That sting is a motherfucker. Fact.
isthisdave is offline
post #13 of 27 (permalink) Old 12-16-2007, 08:01 PM
HalNineThousand's Avatar
Date registered: Oct 2007
Vehicle: 1985 380SL, 1998 230SLK
Originally Posted by page62 View Post
Perhaps breeding Muskrats.
(Sorry, I haven't been the same since the Captain & Tennille's "Muskrat Love was #1 on the pop charts. I'll never be the same again...and it's been 30 years...)
And here's an interesting bit of trivia: on what classic rock album did Toni Tenille do the back up "moaning" vocals and for what group?
Hey, it's either ask a trivia question like that or post whacked out pics of you like what happened to Dugald recently.
HalNineThousand is offline
post #14 of 27 (permalink) Old 12-16-2007, 08:04 PM
Tom
Okay, Meerkats, then.
Or maybe ocelots.
Do they have prairie dogs in your part of Texas?
post #15 of 27 (permalink) Old 12-20-2007, 10:40 AM Thread Starter
cookie79's Avatar
Or maybe ocelots.
Not in this part of the hill country.
Tom
cookie79 is offline
post #16 of 27 (permalink) Old 12-20-2007, 11:54 AM Thread Starter
cookie79's Avatar
Originally Posted by Nascar Fan View Post
It could be something to do with the servo / amp for the heating. Is that system working OK? You could pull that fuse to confirm.
Does it sound like it could be a relay buzzing? All this stuff is in that area.
The heating seems to working OK.
Checking the fuse panel guide I can't seem to identify a fuse for the servo/heating amp. What it be under another name?
I have ruled out wildlife being the cause of "the noise".
I have observed that the auxilliary fan (AF) is constantly going from the time the car is started. The AF will run at different rates when "the noise" is occuring. When "the noise" is absent, the AF runs at a constant speed. I removed the fuse for the AF and "the noise" continued on. (I did this not knowing if relays are before or after fuse panels.)
I have observed that the interior light located below the glove box will flicker when "the noise" is occuring. When "the noise" is not occuring the light stays at a constant brightness.
"The noise" appears to be very close to the fuse panel.
Yesterday I drove the vehicle 50 miles and it ran fine except for "the noise".
Any suggestions as what to do next except for turning p the radio?
Tom
cookie79 is offline
post #17 of 27 (permalink) Old 12-20-2007, 04:31 PM
Nascar Fan's Avatar
Date registered: Feb 2007
Vehicle: 1980 450SL & 1988 560SL
Quoted: 2 Post(s)
Fuse 2 pulls power to the fan. Fuse 10 pulls power from the relay. I think the relay is the problem and pulling the 10 fuse will narrow down the problem. Pull it and report back findings and we will find the intermitten ground path that has it buzzing.
Timing has a lot to do with the outcome of a Rain dance.
Rollin' restore on a
1980 450SL
1988 560SL
Pine Bluff, Arkansas
Nascar Fan is offline
post #18 of 27 (permalink) Old 12-20-2007, 04:49 PM Thread Starter
cookie79's Avatar
Thanks for the information on fuse 10 (AF relay). I should be able to get to it tomorrow.
The noise appears to be coming from one of the relays behind the fuse panel. I pushed the relays thinking perhaps that one could have been loose. When pushing them in, one seemed to be warmer than the others. Can't remember which one it was. will try again tomorrow.
I tried to identify which relay went with the AF, but couldn't figure that out
from my MB factory service CD-Rom
Thanks,
Tom
cookie79 is offline
post #19 of 27 (permalink) Old 12-21-2007, 08:59 AM Thread Starter
cookie79's Avatar
This morning went to check on "the noise". It did not disappoint me. I pulled fuse 10. The fan stopped as did the instrument panel closter. "The noise" continued. While replacing fuse 10, I noticed fuse 12 was blown. I replaced 12(cigar lighter and heated seat). "The noise" was gone. Today the weather in the Austin area will be 77 and sunny, so the real Cookie79 and I will be putting the top down and driving to Kerrville, TX. (150 miles round trip) If "the noise" does not return I will assume that the problem is fixed. (I will also remember an adage that my mother used to say "assume" means you made an ass out of u and me).
I'll report my finding upon our return.
Tom
cookie79 is offline
post #20 of 27 (permalink) Old 12-21-2007, 12:28 PM
Nascar Fan's Avatar
Quoted: 2 Post(s)
My two set of prints show cigar lighter / light & glove box light. either way, I can't see how replacing a blown 12 fuse would have any effect on anything else. Maybe someone has "tapped" the circuit, but still........
1980 450SL
1988 560SL
    Found the source of the "noise" FRONT PASSENGER SIDE gsj224 W163 M-Class 1 12-19-2005 12:06 PM
    Passenger side feet area - (74 sl) gets wet when washed iamtoday R/C107 SL/SLC Class 4 08-27-2005 05:24 PM
    passenger side cam noise ? kmurban500 W126 S,SE,SEC,SEL,SD,SDL Class 4 07-23-2005 04:52 PM
    Rattle noise under the passenger side dashboard area. MikeH W163 M-Class 9 06-06-2003 02:07 PM
    noise behind the passenger side airbag? Crypto W163 M-Class 2 08-30-2002 02:52 PM
