Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 10-24-2007, 04:11 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 1983 Mercedes Benz 380 SL
Turn the key...nothing?
Hi,
Sometimes when I go to start my 83 380 SL I turn the key and get nothing, no idiot lights and the engine will not crank. If I push forward on my shifter in Park the lights will work and the car will start normally. This has just started lately.
Any ideas as to why?
Thanks
Cosmar is offline   Reply With Quote
Old 10-24-2007, 04:35 PM   #2 (permalink)
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 450SLC
Neutral safety switch, or adjustment of said switch.
My computer beat me at chess once, but it was no match for me at kick boxing.
isthisdave is offline   Reply With Quote
Old 10-24-2007, 07:39 PM   #3 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Id on't know if your cars have them or not but my w123 has shifter bushings that go bad mess up the gears. Does your shifter have alot of play in it?
'79 280CE with 212,600 miles and still going strong!!
79Mercy is offline   Reply With Quote
Old 10-24-2007, 07:43 PM   #4 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
Concur. I'd just replace it, bushings too.
flyboyike is online now   Reply With Quote
Smart Key Combination to Turn off Turn Signals Magic Man General Mercedes-Benz 0 09-10-2007 09:04 AM
IGNITION kEY WILL NOT TURN double nickle General Mercedes-Benz 4 07-12-2007 09:09 AM
Problem!!! Key won't turn cdeeznuts W126 S,SE,SEC,SEL,SD,SDL Class 8 12-03-2006 06:19 PM
turn the key and dash lights turn on, no power to starter bob richards General Mercedes-Benz 4 01-13-2006 07:48 AM
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190E, D-Class 4 04-01-2002 12:29 PM
