Need fuse diagram for 1976 450sl
22K views 5 replies 5 participants last post by  rowdie
I'm missing the cover to my fuse box of my 1976 45osl which contains the fuse diagram. I was hoping someone could give me a list of fuses or where to locate a list or fuse panel cover. Thanks
#3 · (Edited)
where to locate a fuse panel cover
I just got a replacement cover from the dealer, about $14. They had to send to Germany for it (at least, they did for a burgundy one) but it took less than a week. The new one did not come with the diagram on the back, but I just reused the one I had (the old cover was cracked and missing 3 of the tabs). I'm sure you could order the sticker from the dealer as well.
#5 ·
1976 450 SL fusebox diagram
I just bought a 1976 450 SL and it had an intact fusebox cover with the fusebox diagram for a USA version attached to the back. I've attached a photo and I've added the wording here in case its hard to read. For chassis number 107-545-15-00.
On the top is a key with a triangle 5 amp (yellow); rectangle 8 amp (white); employ circle 16 amp (red) and filed circle 25 amp (blue). only the radio in position 14 is a yellow 5 amp. All others are either 8 (white) or 16 (red). I've indicated the colors below:
1 - clock, trunk light, standing light right and left, glove compartment light, warning buzzer, hazard warning light, entrance/roof light, electrically operated antenna (white - 8amp)
2 - Auxiliary fan (Red 16 amp)
3 - Power window motor front right + rear left (red 16 amp)
4 - power window motor front left + rear right. (red 16 amp)
5 - horn (unreadable) (sliding roof) (red - 16 amp)
6 - blower motor (red 16 amp)
7 - heated rear window (seat heater UNREADABLE, right and rear) (red - 16 amp)
8 - emission control, seat belt warning system, back up lights, automatic transmission. (white 8 amp)
9 - air conditioning compressor with over drive UNREADABLE (white 8 amp)
10 - stop lamp, turn signals instrument cluster, tachometer, cruise control (red 16 amp)
11 - Windshield wiper, windshield washer pump optical horn (red 16 amp)
12 - cigar lighter, (seat heating front left) (white 8 amp)
13 - tail/parking/starUNREADABLE/ right, side marker UNREADABLE lighting for license plate, thermometer switch, dash board, shift indicator, hazard warning flasher (white 8 amp)
14 - radio (yellow 5 amp)
15 -LEFT BLANK
16 - standing light left, parking light left, tail light left (white 8 amp)
17 - high beam right, high beam indicator (white 8 amp)
18 - high beam left (white 8 amp)
19 - low beam right, fog light (red 16 amp)
20 - low beam left (white 8 amp)
