» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 09-13-2007, 05:32 PM   #1 (permalink)
Serintek's Avatar
Date registered: Aug 2007
Vehicle: Mercedes 1982 380 SL, 1988 560 SEL Navy Blue
Send a message via Skype™ to Serintek
Hope did not screwed the transmission !!!
Got the car few weeks ago, now after 800 miles, transmission started to drip.... loose fluiid.... I looked in the forum and found that MercronIII/Dexron III fluid was appropriate... So I put some into the transmission to replace what was left.. Since then, 2 to 3rd gear is slipping...
Is the fluid I used is in cause ? Simple ATF Dexron III... ?
Now first I have to find the cause of this fluid leak... then fix it...
Martin Richer
New Brunswick Canada
1982 380 SL Grey
2002 Mazda Tribute V6 4X4
1999 Yamaha Roadstar 1600 cc
Serintek is offline   Reply With Quote
Old 09-13-2007, 05:42 PM   #2 (permalink)
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 450SLC
You used the right fluid.
Sometimes, 'flaring', or slipping during the 2-3 shift can be a failing or misadjusted vacuum modulator.
Dave.
My computer beat me at chess once, but it was no match for me at kick boxing.
isthisdave is offline   Reply With Quote
Old 09-13-2007, 07:26 PM   #3 (permalink)
ulflei's Avatar
Date registered: Aug 2005
Vehicle: S 420 300SL
Number one,there is a good chance that you overfilled.
Check with warm and running engine.
Second your leak is mostlikely a seal,which means transmission out an replacing ALL seals.
Labor 13 hours parts $110.
ulflei is offline   Reply With Quote
Old 09-14-2007, 02:36 AM   #4 (permalink)
Date registered: Jul 2005
Vehicle: '83 380SL
My transmission was slipping a couple of years ago after a major service (which included changing transmission fluid), turned out it was vacuum system related.
I also had a leak (seals), just recently had my indie pull it out and reseal it - $1,500.
After getting the car back noticed some minor slipping, will get those vacuum connections tightened up once again.
C230Kto380SL is offline   Reply With Quote
Old 09-14-2007, 04:22 AM   #5 (permalink)
Serintek's Avatar
Thank you all for the advices,
Maybe overfilled as my driveway is lightly sloped... Hopefully did not mess with ATF type... Will have to look for the seals, past owner said it has been rebuilt 2 years ago... maybe just a quick job....
I'll try to call him about it to know better what was done... Meanwhile, it stays parked...
I think I've been screwed. prtdvl R170 SLK Class 4 08-28-2007 06:38 PM
I'm so screwed! :) AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 15 03-12-2007 05:37 PM
Im Screwed! weapon W208 CLK Class 6 08-15-2006 02:24 PM
I screwed up... BETO W163 M-Class 4 12-31-2002 05:47 PM
Did i get screwed? mrhappy71 W210 E-Class 4 08-09-2002 09:32 PM
