» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 05-15-2007, 10:48 AM   #1 (permalink)
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 1978 450SL, 2006 Honda Civic Hybrid, 03 Toyota RAV4
Gas sending unit
Does anyone know the chemistry of the float used in the early 107 models? I know later models used a series of wires, but the cross-section diagram I found for the unit installed in my model year showed a float inside the unit.
Reason I ask is because mine has been off since I got the car, but that's changing. When I first got it, a gauge showing empty meant I still had 9+ gallons left. That's slowly changed until now the gauge showing empty means I have ~5 gallons left. I'd assumed that the float had soaked up the gas and would always be off until I replaced it, but that doesn't seem to be the case. Anyone know what the float is made of? Maybe I don't have to replace the sending unit after all.
When I die I want to go quietly, in my sleep, like Grandpa.
Not screaming, like the people in his car.
ScottinSoCal is offline   Reply With Quote
Old 05-15-2007, 11:03 AM   #2 (permalink)
Date registered: Feb 2007
Vehicle: 1980 450SL
No, but I took apart two (the bottom has a nut you unscrew) 1980 450SL and 1978 450SLC. They were different inside but both had the same float. It was amazing. The float bobs up/down on a center rod. It has two arms that connect connect to a wire. This creates a variable resistor. More gas less resistance. Less gas, more resistance. I cleaned off the crud along the wires and rod (there was a lot) and mine started working after being stuck on "full" (it had sat for 4 years with a full tank of gas). At first it would sometimes read lower than I new was in the tank. I figured I had not clean well enough or the little arms were not making good contact. Recleaned, no problems.
Hope this helps. I can send a photo of the 1978 SLC if it would help.
Klonorg is offline   Reply With Quote
Old 05-15-2007, 11:29 AM   #3 (permalink)
Date registered: Nov 2006
Vehicle: 73 450SL
Scott, I hope you don't mind me jumping in here. I have a simular probem with my gas guage. I was about to post and here I find yours. Any info or pics would be great.
NormanB is offline   Reply With Quote
Old 05-15-2007, 11:50 AM   #4 (permalink)
Much help - thank you. Is the float a solid foam, or is it a hollow container? It might just be the wire that needs to be cleaned inside it. It sat for most of the 4 years previous to me getting it, so I'm sure the old gas fouled things.
Old 05-15-2007, 11:51 AM   #5 (permalink)
The more the merrier.
Old 05-15-2007, 01:24 PM   #6 (permalink)
Vehicle: 73 450SL
Thanks
My problem is more of a stability of the fuel guage. When I first got the car (2 weeks ago) the guage was OK until about 3/4 of a tank then the needle started bounce around and getting worse as the gas level fell. Once it got to about 3/8 the needle just stayed on E. Now the guage seems more stable until under a 1/2 then starts it's games.
Is my problem the same as Scott's a dirty sending unit?
Old 05-15-2007, 01:45 PM   #7 (permalink)
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC, RHD, Ikonengold 419, pergament 205, 82t km's
Location: Serbia, South Africa, Australia, Jamaica... actualy ROTW!
Warning! SLNV rated picture
It can be this part in the middle of the bottom, just under the first aid box place?
Djenka018 is offline   Reply With Quote
Old 05-15-2007, 01:50 PM   #8 (permalink)
smack's Avatar
Date registered: Sep 2006
Vehicle: 1973 450SL 1991 420SEL 2008 Jeep Commander
Gotta be uncomfortable driving. Actually, thanks guys, this was an informative thread.
My Mercedes keep me so broke, I can't even pay attention!!
smack is online now   Reply With Quote
Old 05-15-2007, 05:47 PM   #9 (permalink)
ussun's Avatar
Date registered: Jun 2006
Vehicle: 1973 450 SLC AMG
Man that reminds me of driving around in my friend MG on milk crates. AH the good old days.
PS. I can only hope your sl's c's are driving as nice as mine is
Ah that magic feeling of being post mortgage and zero debt. (between repairs)
ussun is offline   Reply With Quote
Old 05-15-2007, 06:29 PM   #10 (permalink)
Vehicle: 1980 450SL
Float
The float seems to be made of a solid material. You can see if the wires get encrusted the contact is poor and the resistance can vary.
Temp sending unit khaledfarid R/C107 SL/SLC Class 3 01-27-2007 08:30 PM
Speedometer sending unit? dalek W126 S,SE,SEC,SEL,SD,SDL Class 0 10-08-2006 06:03 AM
Temperature Sending Unit eks3703 R/C107 SL/SLC Class 2 12-15-2004 06:36 PM
gas sending units Guest (MBNZ) W203 C-Class 4 07-23-2002 07:11 AM
DIY - Gas Sending Unit Replacement Guest (MBNZ) W124 E,CE,D,TD Class 2 07-09-2002 12:48 PM
