Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 04-04-2007, 08:10 AM   #1 (permalink)
Date registered: Feb 2007
Oil Loss- Valve stem seals
I posed this question on another board, but thought I would see if anyone here could help. My '83 280SL is going through a lot of oil each week. There doesn't appear to be a leak, and no "sign of burning" that I (or the mechanic) can tell. The mechanic thinks that the valve stem seals are the problem and need to be replaced. He has quoted me at close to $1100 (parts/labor) for the job. That is a lot of money to spend when we are not even sure that is the problem. Any thoughts/advice on this?
jbaril02 is offline   Reply With Quote
Old 04-04-2007, 08:32 AM   #2 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
Two questions:
1. Any smoke in the exhaust?
2. Have you looked to see if there is oil on the spark plugs?
If the answer to both is no, I would doubt the valve seals as being suspect. I would check to see if there is oil in the coolant.
flyboyike is offline   Reply With Quote
Old 04-04-2007, 08:56 AM   #3 (permalink)
1) the exhaust is always dark/smoking - but this is a "euro" (so the emissions may be different). Also, this car sat for a couple of years before I got it to fix up and has quite a few replaced fuel parts - so I don't know if that makes a difference or not.
2) I have not checked that yet, but will try to do so (as you can tell from my posts in the past, I am a novice at mechanics - but always willing to learn).
Old 04-04-2007, 09:02 AM   #4 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
Smoke in the exhaust is not normal, Euro or not. BTW, how is the idle quality?
Old 04-04-2007, 09:12 AM   #5 (permalink)
The idle appears fine. Is there something I should be looking for? (knocking, a certain RPM for this model, etc.)?
Old 04-04-2007, 09:14 AM   #6 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
No, but sometimes the engine will skip due to oil-covered spark plugs not producing enough spark. I'm concerned about your exhaust having "always been smoking". That needs to be investigated.
Old 04-04-2007, 09:28 AM   #7 (permalink)
Would the valve stem seals be the issue there (and solve both problems) or should I be investigating something else?
Old 04-04-2007, 09:29 AM   #8 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
They can be, yes. Is the smoke blue?
Old 04-04-2007, 09:36 AM   #9 (permalink)
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 1978 450SL, 2006 Honda Civic Hybrid, 03 Toyota RAV4
Black smoke or blue?
When I die I want to go quietly, in my sleep, like Grandpa.
Not screaming, like the people in his car.
ScottinSoCal is offline   Reply With Quote
Old 04-04-2007, 10:32 AM   #10 (permalink)
I thought it was black, but I just started it to look. Its a light grey, not too dark right now (although its in a parking garage). I don't know if I'd describe it as blue necessarily.
New valve stem seals created rough idle Gregs300CD W123 E,CE,D,CD,TD,TE Class 8 06-28-2006 06:58 PM
valve stem seals replacememt ??? Guest (MBNZ) W201 190E, D-Class 4 08-03-2005 04:10 PM
Replacing valve stem seals bkv W124 E,CE,D,TD Class 0 09-30-2002 11:42 PM
Valve Stem Covers Mike M R170 SLK Class 6 03-11-2002 03:46 PM
valve stem seals replacement ???? Guest (MBNZ) W124 E,CE,D,TD Class 3 03-02-2002 10:32 PM
