Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 01-31-2007, 10:18 PM   #1 (permalink)
Date registered: Jan 2007
Unhappy PLEASE HELP ! ! Wipers don't work..
Hello Guys...I am new to the site but not to the SL. I have had this 1972 grey market 350SL chass. # 107.043 since 1980. I would really like to know where the wiper relay is located. Also, if you can think of anything else that it could be since this thing has so many different speeds located on the directional switch. Do you think it could be the switch and is there any way I can test any of these things to know for sure. If I could locate the correct relay I would change it just because it's old and it couldn't hurt. Especially considering the cost of a relay compared the whole switch $$$$$.
Axiously awaiting your replies....
beachbummer505 is offline   Reply With Quote
Old 02-01-2007, 04:29 AM   #2 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
I'm going to assume that you've checked the fuse and it's OK. Replace it anyway just to be absolutely sure. Then check for voltage at the wiper motor. If it's getting power, the motor itself is the problem. If not, now you're back to either the switch or the relay. I'm pretty sure the wiper relay is one of the six silver ones mounted behind the passenger kick panel, just above the fuse box. If it's not there, it's behind the lower driver's side dash panel, above your shins. Take a look and report back.
flyboyike is offline   Reply With Quote
Old 02-01-2007, 11:55 AM   #3 (permalink)
cruicky68's Avatar
Date registered: Sep 2006
Vehicle: 1978 450SLC W107:1987 230CE W124: Looking For More Mercs
One of t he best tools you can buy for sorting out electrical gremlins is the Power Probe. It allows you to power componets like your wiper motor to allow you to check if its the motor at fault. The probe has two wires that can either be connected directly to a 12 volt battery, or a plug that fits directly into your cigar lighter. It also has an earth/return wire with a crocodile clip. You connect that to one side of your motor then use the probe to touch the other. The push the switch on the probe to power the component. Great item of kit espcially for testing old component before you spend money on new parts
cruicky68 is offline   Reply With Quote
Old 02-01-2007, 10:36 PM   #4 (permalink)
Hi flyboyike and Thank You for getting back to me so quickly....I'm sorry I should said that the fuse was the first thing I looked at,unforunately though it is all in German so I'm not quite sure what wipers would be...However I did check all the fuses and they seem fine. Pretty easy to tell on those old ceramic ones....Thanks for your time...
Old 02-01-2007, 10:41 PM   #5 (permalink)
Hi cruicky68 and Thank you for geeting back so quickly... Power Probe ...Never heard of that...Great idea though..I will check into that...Sure is cheaper then taking it somewhere..... Thank you so much ...I'll keep you posted... Any idea on where to purchase this ??? Any Auto parts store ????
Old 02-02-2007, 06:20 AM   #6 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
Wischblatter.
Old 02-02-2007, 11:31 AM   #7 (permalink)
Thank you for that...I should have guessed sounds like windshield...Thank you I will change that one....Do you know where the wiper motor is located on that car ??? I appreciate all your help....
Old 02-02-2007, 01:24 PM   #8 (permalink)
cruicky68's Avatar
Hi,
Power probes are made by just about every tool manufacturer, MAC, Snap On etc. I've found this web-site that looks to be US based. Mine cost about £40 here in the UK
powerprobe
Good luck & keep me posted
Old 07-03-2008, 07:05 AM   #9 (permalink)
richardr's Avatar
Date registered: Mar 2008
i have a 86 560sl and the problem with mind is it gos on by its self
driving and wiper just gos on and off > is that a relay probem??
richar r
richardr is offline   Reply With Quote
Old 07-03-2008, 07:50 AM   #10 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed
richar r
It goes on and off without touching the stalk? I would say the relay IS working properly and your stalk heeds to cleaned / replaced.
Why do psychics have to ask you your name?
nobby is online now   Reply With Quote
Intermittent Wipers do not work jetmal W163 M-Class 8 06-08-2006 12:20 PM
Wipers work sometimes Nimrodthewombat W140 S-Class 6 04-19-2006 08:41 AM
Headlight Wipers don't work andreifs W124 E,CE,D,TD Class 6 02-09-2006 04:00 PM
My windshield wipers don't work eyegotta75_240D Vintage Mercedes-Benz 1 11-16-2005 06:24 PM
MAKE THOSE HEADLIGHT WIPERS WORK! Chupper W124 E,CE,D,TD Class 6 12-24-2002 08:33 AM
