Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 12-20-2006, 09:25 AM   #1 (permalink)
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 1978 450SL, 2006 Honda Civic Hybrid, 03 Toyota RAV4
How to get a new window switch in just 12 easy steps
1) Read a thread that talks about how easy it is to clean sticky window switches.
2) Ponder the thread a few days, while you consider your sticky passenger window switch.
3) Experiment with taking the console apart.
4) Decide 'what the hell' and remove the switch.
5) Carefully take apart the switch and try cleaning it with a dental pick, like the thread shows.
6) Realize it's too gunked up and drop everything into an ultrasonic cleaner with a heavy duty degreaser solution.
7) Run three cycles, until all parts are pristine.
8) Carefully dry all parts.
9) Grease all parts for smooth operation.
10) Reassemble switch and test for proper operation.
11) Insert switch back into console, being sure to break the top plastic surround piece.
12) Buy a new set of window switches.
It's really easy. And the new switches look great.
When I die I want to go quietly, in my sleep, like Grandpa.
Not screaming, like the people in his car.
ScottinSoCal is offline   Reply With Quote
Old 12-20-2006, 03:00 PM   #2 (permalink)
smack's Avatar
Date registered: Sep 2006
Vehicle: 1973 450SL 1991 420SEL 2008 Jeep Commander
Again, Scott...
....your repairalogues are a source of delight to us all. The more you dig in, the more I think I can live with many of the little nuances of my 450SL. Fortunately, the former owner was a German master mechanic by the name of Helmut - how could I go wrong. All the little things have been tended to. The thing that is your most valuablee contribution is that you make us all pay attention to this stuff so we never get comfortable thinking all is well. Keep them up dude.
My Mercedes keep me so broke, I can't even pay attention!!
smack is online now   Reply With Quote
Old 12-20-2006, 03:29 PM   #3 (permalink)
KTT
KTT's Avatar
Date registered: Oct 2006
Vehicle: 1986 560SL
13) Buy additional set of switches once you realize the ones you bought were not lighted, like OEM.
KTT is offline   Reply With Quote
Old 12-20-2006, 07:36 PM   #4 (permalink)
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
Does anyone else have the problem of the LH switch insert for the window symbol wearing out. My switches work fine but the symbol is worn and light shows through. Too bad they aren't replacable...an interesting project would be to dig the insert out and replace it with a plastic laminated piece, maybe made with a few layers of laser/inkjet paper with laminate over it.
_________________________
Homebrew MB First Gear Start!
http://juliepalooza.8m.com/sl/mercedes.htm
strife2 is online now   Reply With Quote
Old 12-20-2006, 07:52 PM   #5 (permalink)
My switches weren't lit when I got the car, so I replaced them with the same type of switch.
Old 12-20-2006, 07:54 PM   #6 (permalink)
KTT
KTT's Avatar
Vehicle: 1986 560SL
strife2, same problem here. Sounds like a visor clip opportunity.
Old 01-01-2007, 12:44 AM   #7 (permalink)
Date registered: Jun 2005
my driver window stock last 2 weeks but now fixed.
cheap parts,my old nissan cost triple.
easy to replace just open your latch cover,remove the 2 screws,then pull it up and then just carefully pull the wood trim fom there you can see everything.
pete03 is offline   Reply With Quote
easy question about hazard switch removal smallfence W123 E,CE,D,CD,TD,TE Class 2 02-20-2006 09:48 PM
Window switch dannyqball_817 W163 M-Class 4 02-17-2006 05:33 PM
Window Switch SXN_280 W126 S,SE,SEC,SEL,SD,SDL Class 8 11-24-2005 02:31 AM
window switch lnkprksoldier W124 E,CE,D,TD Class 0 04-26-2005 08:06 PM
window switch Tatnhu W163 M-Class 6 12-02-2004 06:15 PM
