Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 10-10-2006, 06:49 PM   #1 (permalink)
Date registered: Sep 2006
Help! Have Part #, Need Name
Hello! I'm trying to track down a very high idle speed in my '81 380sl. I've screwed up while jumping the battery (switched cables) and it now revs at 1700 RPM.
I can't find what looks like an OVP, but I did locate the following relay where the OVP usually is located.
Can someone tell me what this part number is?
107 820 01 10
Thanks!
Michael
MichaelMBZ is offline   Reply With Quote
Old 10-10-2006, 07:09 PM   #2 (permalink)
ussun's Avatar
Date registered: Jun 2006
Vehicle: 1973 450 SLC AMG
I was just reading about mb idle setting they said you should bring it to a reliable machanic to set a sl idle cuz ya need special tool and gages. About the part # I did some searching and I need more info or it wrong. What's it for?
ussun is offline   Reply With Quote
Old 10-11-2006, 09:02 PM   #3 (permalink)
KCM
Date registered: Jun 2004
107 820 01 10, replaced by 107 820 00 10, is the relay for the rear window defroster.
You might check the throttle position sensor. My 560 was idling high and the sensor was bad. There are three terminals. #2 terminal is common, #1 has continuity at idle and open at other speeds, #3 has continuity at full throttle and open and lesser speeds.
There is an idle control circuit composed of a control unit, temperature switch, control valve, and other inputs. Could be any of these items that is causing the problem.
KCM is offline   Reply With Quote
Can anybody help? Looking for this part... C-2 W210 E-Class 1 06-16-2006 01:28 PM
Can someone tell me what is the name or part number for this part shown in picture! stsintx R129 SL Class 4 01-24-2006 07:58 AM
MB part #'s vs rebuildt or reconditioned part #'s jmul W123 E,CE,D,CD,TD,TE Class 4 06-05-2005 07:41 PM
Opinions - If any part of the SLK could be given a chromed look, what part would Loi R170 SLK Class 11 06-06-2003 06:42 PM
One part car, one part billy goat... Drew W163 M-Class 5 11-20-2001 08:53 PM
