I need to update the website I put up earlier. The last two days I have been repairing my vacuum elements. I finished Sat nite, and took her for a shake-down run. Everything still works to my great pleasure (never know since you have to disturb SOOOOO much stuff).
Summary:
Took out radio, climate controls, shifter wood, console, glove box, carpets, under-dash panels, carpeted bolster and eventually driver's seat. All this to get at the bottom of the heater box. After removing a few other asundry parts, I removed the bottom of the heater box, repaired crack(s) via mending plate, and renewed the legroom vacuum element. Next I reached up inside heater box, and thru the front vent, and removed the center vent pod. I repaired broken box via mending plate, renewed vacuum element, and re-installed (since my heater box was broken, I could easily remove the pod by dropping it down after disengaging the lever from the flap). I reinstalled the bottom of the heater box and then attacked the Defroster pod. After grinding a bit, I was able to disengage the operating lever, grabbed my pod-popper, and pulled out the little bugger (leaving the top part still in the mount). I renewed the elements, and reinstalled using a #8-32 pan-head allen screw and nylon lock nut to reattach the operating lever. Buttoned everything back up and VOILA!
I should mention my loving wife shampoo'ed the carpets while they were out, bless her heart!
I'll try and post more info later...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
