560SL vs. (560SEL & 560SEC) Engine Differences - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-05-2006, 07:15 AM Thread Starter
Date registered: Mar 2006
I have an '87 560SL that could certainly benefit from a fresher engine replacement. I have seen several statements in the past that the engine from a 560SEL or 560SEC would work well in my 560SL "with slight modifications". I have no idea what, specifically, this means.
Does anyone have a link or can provide some specific insight as to what "slight modifications" would be necessary to make this engine swap work?
Many thanks,
parrots
parrots is offline
post #2 of 6 (permalink) Old 03-05-2006, 09:50 AM
Date registered: Oct 2005
Vehicle: '82 380 SL, '82 300TD, '85 500SEC
RE: 560SL vs. (560SEL & 560SEC) Engine Differences
Having been under both cars, I'd imagine the "modifications" start with the shape of the oil pans. They are different looking so as to clear chassis cross members in different positions. Also, one is one-piece and othe other is two, with a removable lower portion. I'd guess the modifications include a pan swap which would seem straightforward. My parts guide says both pan gaskets are the same...so it would be easy. But don't quote me 'cause I've never done it. I'd suggest starting your research with the oil pan
daveward is offline
post #3 of 6 (permalink) Old 03-05-2006, 01:14 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
daveward - 3/5/2006 10:50 AM
They pretty much end there as well.
flyboyike is offline
post #4 of 6 (permalink) Old 03-05-2006, 01:55 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
Yup -- just swap oil pans and you should be in business.
GeeS is offline
post #5 of 6 (permalink) Old 03-08-2006, 01:27 PM
London380sl's Avatar
Vehicle: 1984 380sl, 1988 300ce, 1988 420sel (gone)
Quoted: 9 Post(s)
Try this link
http://www.carcentric.com/MB2MBswap.htm
It should give you all the answers you need [:)]
London380sl is offline
post #6 of 6 (permalink) Old 03-08-2006, 01:48 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
Wow -- great link London.
GeeS is offline
