» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 09-03-2005, 08:26 AM   #1 (permalink)
Date registered: Oct 2003
Vehicle: 81 380 sl, 95 e320
timing chain tensioner slap
81 380sl with a single chain.
i have had the car for 8 yrs and have had the chain and guides replaced twice. occasionally on cold start the timing chain makes "that noise" for a second or two. why didnt the repair / replacement solve the problem. i think i read that there are guides on the bottom too..??
any thoughts would be appreciatted.
david
flathman is offline   Reply With Quote
Old 09-03-2005, 10:27 AM   #2 (permalink)
Teutonic's Avatar
Date registered: Aug 2005
Vehicle: Red 1987 560SL
RE: timing chain tensioner slap
I have a 1987 560SL. The timing chain on my 560 used to make a "rattling noise" for a couple of seconds during a cold start. The cause of this is a bad hydrolic tensioner that is mounted on the front-side of the engine block next to the timing chain. The tensioner is suppose to keep the chain tight when the engine is cold. When the engine starts, hydrolic pressure flows to the tensioner and it will do its job. I had my tensioner replaced this month - about a two-hour job for a mechanic - and that solved the problem and the "rattle noise". Do not let this problem go for very long. If the slack chain were to jump off, you would lose the engine.
I'm not a mechanic. All of what I've told you here was told to me by two different mechanics.
-Teutonic Tomato
Teutonic is offline   Reply With Quote
Old 09-03-2005, 12:21 PM   #3 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
Teutonic is right. The tensioner is probably on its way out.
flyboyike is offline   Reply With Quote
Old 09-16-2005, 12:44 PM   #4 (permalink)
Captain Scott's Avatar
Date registered: Apr 2005
Vehicle: 1974 450 SL
My 74 450SL (212K miles) is doing the same thing and I am concerned. The car used to live in Socal and I called the mechanic who replaced the chain+rails a four years back. He said just change the tenioner and it will be fine.
But a local Seattle mercmech that I stopped by recently, told me that the chain/rails/tensioner should all be changed. I thought the shop rate for that is something like 15 hours. and I don't have an extra $2000 laying around, but sure don't want to have to rebuild the engine either. Changing the tensioner should be fairly easy and not too costly compared to other avenues.
Does anyone have and advice on pitfalls or hints regarding the tensioner?
Scott
Captain Scott is offline   Reply With Quote
Old 09-20-2005, 05:42 PM   #5 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
at 212K your are getting close to needing the lower rails changed so I would save a few $$ and plan on that job in the not so distant future.
You might try dropping a new tensioner in..they are not hard to change, 20-30 minutes at most.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is online now   Reply With Quote
