Here's mine. 1973 450SL
I just imported it into Canada on March 20, 2008. She had a total of 112,600 miles on her when imported. The only major item done to this car over the years was bare metal repaint at 103k miles in 1998. She was driven 80k miles from date of original purchase until Mar. 1988, and then only 13k miles by Feb. 98, and a further 10k miles by date of import into Canada. All Interior is original, and I have ordered an original Becker Radio to replace the after market Kenwood that's in there now. The original Soft Top is in near perfect condition (plastic windows require polishing). Plastic windows are clear, but there are some areas of abrasion.
To Do:
Fuel Leak in injector lines - Done
Trunk Light, Glove Box Light, Clock don't work - Done
Power Locking system doesn't work - Done
Window rattle on drivers door when window down - Done
Turn Signal won't stay in position for right turns - Done
Air Cleaner Horn Mount broken - Done
Fan Shroud missing bolt - Done
Front Lower Cowl missing bolts - Done
Foam pad rear of hood to be installed - Done
Chrome rear bumper joint trim - To Replace
Chrome trim left side of trunk release - To Replace
Front Lower Cowl to be - straightened and painted
Stainless Rocker panel trims - to be removed and polished
Rad tank, Air Cleaner, bottom end of Rad - To be painted
AC/Heater control assembly broken - To be replaced
Break release knob - to be replaced
Front left bumper section dented - To be replaced
Hard Top window seals - To be replaced
A - Pillar seals to be replacd
White rubber trim at firewall - to be re-glued
Hub Caps - To be completely refinished, or replaced
Wheels - To be painted
Rocker Panels - To be painted
A few other misc. body work items to be done.
The photos on my site show all of the areas of concern.
I will be updating the site as these items are done.
Visit my site:
450sl
I only hope I can get it to look as good as NormanB's
http://www.benzworld.org/forums/r-c1...ml#post2503006
Loren
