Stalling Quiz: WINNER GETS $50 - Mercedes-Benz Forum
post #1 of 91 (permalink) Old 06-06-2009, 06:17 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1123 Post(s)
Exclamation Stalling Quiz: WINNER GETS $50
What is your best guess? Winner gets $50
Car: 1988 190E 2.3 8V
Problem: stalls at a stop or while slowing down to a stop (All random)
Parts replaced:
1. Fuel pump
2. Fuel filter
3. Fuel Pressure Regulator
4. Fuel accumulator
5. ICV
6. ICV hoses
7. Air meter rubber boot
8. Crank position sensor
9. Fuel pump relay
10. OVP
11. Temperature sensor
12. O2 sensor
13. Catalytic converter
14. Exhaust
15. Resonator
16. Spark plugs
17. Ignition wires
18. Ignition rotor
19. Ignition cap
20. Battery
21. Voltage regulator
22. Breather hose
23. Breather hose coupling
24. Fuel cap
25 EHA washers
What was done:
Adjusted EHA and Lambda
Checked fuel pressure
Checked fuel flow for each injector
Checked main fuel flow and quantity
Air plate adjusted
If your suggestion fixes the problem then you will get $50. So far this problem has lasted one year and not a single suggestion from any of the forums has provided a solution that eliminated this stalling.
Rules: You must state step by step the procedure that you would undertake. It must be replicated by an idiot like me and will not require that I end up in the hospital. In addition, replacing the whole engine or complete systems are not acceptable solutions. You must pinpoint a specific problem, support it then list and describe exactly how you would go about it.
Before I implement your solution it must be vetted. Once I agree to go with your solution there will be a testing period of two weeks before I declare you a winner.
Note: This competition is listed in several forums
I reserve the right to terminate this competition at will
DP is offline
post #2 of 91 (permalink) Old 06-06-2009, 06:33 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
"It's your alternator"
Nutz 4 Benz is offline
post #3 of 91 (permalink) Old 06-06-2009, 06:34 PM Thread Starter
DP
DP's Avatar
Support this theory
DP is offline
post #4 of 91 (permalink) Old 06-06-2009, 06:51 PM
Date registered: Feb 2007
Vehicle: 300SD
Quoted: 62 Post(s)
That's a lot of replaced parts. Are you just throwing parts at it at random?
The problem as I see it is most likely in the idle circuit, and something is deliberately triggering the fuel pump relay to shut down the fuel pump as the RPMs drop too far. Do you see a steep drop in RPMs just before the car stalls?
p100 is offline
post #5 of 91 (permalink) Old 06-06-2009, 06:52 PM
yoseyman's Avatar
Date registered: Nov 2005
Vehicle: Baby
There is a nut loose behind the wheel
DP likes this.
yoseyman is offline
post #6 of 91 (permalink) Old 06-06-2009, 06:52 PM
Vehicle: 300SD
Quoted: 62 Post(s)
No, I am sure it is caused by the radio antenna being too short.
DP likes this.
p100 is offline
post #7 of 91 (permalink) Old 06-06-2009, 06:56 PM Thread Starter
DP
DP's Avatar
Random? I am just going by the suggestions of all of our members
http://www.benzworld.org/forums/w201...ing-again.html
It does do that sometimes where the rpm drops a little and sometimes surges back before going to zero, the fuel pressure drops then boom it stalls. Today for example it was nice and steady then it went to zero just like that. There is no set pattern here.
DP is offline
post #8 of 91 (permalink) Old 06-06-2009, 06:57 PM Thread Starter
DP
DP's Avatar
Which one?
DP is offline
post #9 of 91 (permalink) Old 06-06-2009, 06:58 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 113 Post(s)
Send a message via AIM to edfreeman
Pearls of wisdom.
Good to "see" you.
DP likes this.
edfreeman is offline
post #10 of 91 (permalink) Old 06-06-2009, 06:59 PM
yoseyman's Avatar
Vehicle: Baby
Originally Posted by drewprof View Post
Which one?
I would consult grasshopper but....
yoseyman is offline
Stalling Quiz: WINNER GETS $50 DP W201 190-Class 44 06-12-2009 08:00 AM
ferrari quiz full house Off-Topic 14 09-21-2007 04:14 PM
Quiz benzover C208/A208 CLK-Class 9 06-09-2007 07:28 AM
This is a quiz bgoin W201 190-Class 3 07-01-2006 02:00 AM
Easiest Quiz firstmb Off-Topic 2 02-24-2006 09:51 AM
