Stalling Quiz: WINNER GETS $50 - Page 6 - Mercedes-Benz Forum
post #51 of 91 (permalink) Old 06-07-2009, 03:58 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1120 Post(s)
Originally Posted by ogrenutz View Post
Drive it to Potomac German. Take whatever they give you for it. Go home. Let me know where to get the 50 spot.
Not valid! You need to provide a repair solution not a
DP is offline
post #52 of 91 (permalink) Old 06-07-2009, 06:36 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 640 Post(s)
Fuck this, I'll pay someone $100 to go to Drew's house, fuck him in the ass, steal his car and drive it into the ocean so we don't have to hear this shit anymore.
DP likes this.
Qubes is offline
post #53 of 91 (permalink) Old 06-07-2009, 06:41 PM Thread Starter
DP
DP's Avatar
I will pay $150 for someone to sneak in at night and spray paint Qbn's SLK completely pink.
DP is offline
post #54 of 91 (permalink) Old 06-07-2009, 06:42 PM
yoseyman's Avatar
Date registered: Nov 2005
Vehicle: Baby
Again?
Digmenow and DP like this.
yoseyman is offline
post #55 of 91 (permalink) Old 06-07-2009, 06:42 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 95 Post(s)
I'll PayPal you half of that....
isthisdave is offline
post #56 of 91 (permalink) Old 06-07-2009, 06:43 PM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 640 Post(s)
^ You talkin' to me?
Qubes is offline
post #57 of 91 (permalink) Old 06-07-2009, 07:32 PM
isthisdave's Avatar
Quoted: 95 Post(s)
Just offering to help defray your out of pocket...
post #58 of 91 (permalink) Old 06-07-2009, 09:10 PM
lovemyc280's Avatar
Date registered: Oct 2003
Vehicle: 2004 Lexus LS 430 Modern Luxury. 2012 Acura TSX (fun fun) Maybe MB again one day...
Quoted: 109 Post(s)
I'll do it for 75 and a BW premium account membership.
Thanks.
DP likes this.
lovemyc280 is offline
post #59 of 91 (permalink) Old 06-08-2009, 07:45 AM
Date registered: Sep 2004
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 256 Post(s)
Drew,
I don't have any 8 valve 190E experience but I think many of the fuel and ignition features are the same. On a 16 valve 190E there is a set of micro switches on the throttle linkage to shut the fuel off when you remove your foot from the throttle pedal at load abruptly, then, by having the linkage drop to its idle position and close the lower micro switch, set the computer to catch the rpm dropping through around 1800 rpm so that it idles. If the second micro switch is either broken or gummed up you don't give the computer the signal and you get a stall. I have had to clean this item on each of our 16 valve units several times.
The same with the "idle motor" between cylinders 2 and 3. We have to remove it and soak it in Sea Foam or the like overnight and then drain it and put it back in - if it is gummed up it may seem to work when you bench test it, but if it is reacting too slowly and you have that fuel saving micro switch bullshit set up it lets the car stall. I do not believe all the vehicles of the era had the micro switch set up. While it is a complication and needs to be attended to once the area gets gunked with dirt and grease and the like, the switches are simple and reliable. Just the linkage that needs to be kept clean. I use a spray electrical part cleaner liberally and then spray it with a lithium grease lube lightly.
Good luck - this stuff can be a pain. But it sounds like the car restarts, so, remember, shit can be worse. Count your "blessings."
Jim
JimSmith is offline
post #60 of 91 (permalink) Old 06-08-2009, 07:50 AM
Bill F's Avatar
Date registered: Oct 2007
Vehicle: B200 T 2007 Gone, Discovery Sport 2016
Quoted: 7 Post(s)
What is your best guess? Winner gets $50
Car: 1988 190E 2.3 8V
Problem: stalls at a stop or while slowing down to a stop (All random)
If your suggestion fixes the problem then you will get $50. So far this problem has lasted one year and not a single suggestion from any of the forums has provided a solution that eliminated this stalling.
Rules: You must state step by step the procedure that you would undertake. It must be replicated by an idiot like me and will not require that I end up in the hospital. In addition, replacing the whole engine or complete systems are not acceptable solutions. You must pinpoint a specific problem, support it then list and describe exactly how you would go about it.
Before I implement your solution it must be vetted. Once I agree to go with your solution there will be a testing period of two weeks before I declare you a winner.
Note: This competition is listed in several forums
I reserve the right to terminate this competition at will
It Sounds like a bad pick up coil in the distributor and or a bad bearing in the distributor. Check for play in the bearing by moving the rotor if no play then it sounds like the pick up coil is bad.
Is the money in a stable currency or the U.S. green back and is this contest associated with a free time share????
Bill
Bill F is offline
Stalling Quiz: WINNER GETS $50 DP W201 190-Class 44 06-12-2009 08:00 AM
ferrari quiz full house Off-Topic 14 09-21-2007 04:14 PM
Quiz benzover C208/A208 CLK-Class 9 06-09-2007 07:28 AM
This is a quiz bgoin W201 190-Class 3 07-01-2006 02:00 AM
Easiest Quiz firstmb Off-Topic 2 02-24-2006 09:51 AM
