Stalling Quiz: WINNER GETS $50 - Page 3 - Mercedes-Benz Forum
post #21 of 79 (permalink) Old 06-06-2009, 09:38 PM
37x
Date registered: Feb 2009
Vehicle: 72 Pinto
Quoted: 98 Post(s)
Did you replace the MAF sensor?
37x is offline
post #22 of 79 (permalink) Old 06-06-2009, 09:50 PM
bsmuwk's Avatar
Date registered: Jun 2008
Vehicle: Depends on the week
Quoted: 34 Post(s)
Originally Posted by p100 View Post
Volkswagen had a big problem with defective ignition coils on their late model Jettas several years ago. They used a water spray test to see if the coils would arc. Apparently the coil insulation was defective. Did you check you coil? You can check the primary and secondary resistance with an ohmmeter, and if you have a megger, also the insulation resistance. But the water spray test is a quick sanity check.
Ding Ding Ding, we have a winner. M102 and M103 ignition coils were known to "delaminate" and cause all sorts of problems. You could be dying at idle and running like a bat out of hell WOT, or you could be running like a bad out hell at idle and dying at WOT. Same as makes no difference, definitely check your coil. All $49.99 goes to p100. If it's not the coil, then take it to Mercedes and get the ICU checked out.
☆ ★ A R T I S A N ☆ ★ ☆ ★ A R T I S A N ☆ ★
Chicagoland Mercedes Facebook Group: https://www.facebook.com/groups/mbclubchicago/
Join the W124 Buy/Sell/Trade/Chat Group on Facebook : https://www.facebook.com/groups/224626884381433/
http://artisanexcite.blogspot.com/
Mercedes Diesel Injector Servicing: http://artisanexcite.blogspot.com/p/...servicing.html
bsmuwk is offline
post #23 of 79 (permalink) Old 06-06-2009, 09:53 PM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1436 Post(s)
Originally Posted by drewprof View Post
What is your best guess? Winner gets $50
Car: 1988 190E 2.3 8V
Problem: stalls at a stop or while slowing down to a stop (All random)
If your suggestion fixes the problem then you will get $50. So far this problem has lasted one year and not a single suggestion from any of the forums has provided a solution that eliminated this stalling.
Rules: You must state step by step the procedure that you would undertake. It must be replicated by an idiot like me and will not require that I end up in the hospital. In addition, replacing the whole engine or complete systems are not acceptable solutions. You must pinpoint a specific problem, support it then list and describe exactly how you would go about it.
Before I implement your solution it must be vetted. Once I agree to go with your solution there will be a testing period of two weeks before I declare you a winner.
Note: This competition is listed in several forums
I reserve the right to terminate this competition at will
  • Pick up a working telephone.
  • Dial 410-987-0130.
  • Ask for Claude.
  • Make appointment.
  • On scheduled day, drop faulty vehicle off between 8 AM and 8:30 AM.
  • Return before 6 PM and reclaim perfectly functioning vehicle by paying a fair but not inexpensive price for services rendered and parts replaced or repaired.
  • Return home for incredibly hot monkey love.
Autohaus
215 Najoles Rd
Millersville, MD 21108
Tel: 410-987-0130
Hours: Mon-Fri 8:00am-6:00pm
Quis custodiet ipsos custodes?
Digmenow is online now
post #24 of 79 (permalink) Old 06-06-2009, 10:02 PM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 4 Post(s)
Did you check the antisemetic diatribe valve? It's right next to the oil.
ThrillKill is offline
post #25 of 79 (permalink) Old 06-07-2009, 02:41 AM
jplinville's Avatar
Date registered: Sep 2008
Vehicle: 1987 560SL
Send a message via AIM to jplinville
It's Bush's Fault!!!
Ok, here's what you do. Take the car to a local garage that has a 4 post lift...this is very important. Now, take the lift all the way up to the top and inspect everything underneath. Next, have someone park a 107 with your name on the title underneath it.
Problem solved...no more problems with the baby benz
I'm not a real dickhead...but I acted like one in high school.
jplinville is offline
post #26 of 79 (permalink) Old 06-07-2009, 07:05 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1038 Post(s)
Ok P100, I am going to test the main coil sometime today.
DP is offline
post #27 of 79 (permalink) Old 06-07-2009, 07:05 AM Thread Starter
DP
DP's Avatar
  • Ask for Claude.
  • Make appointment.
Autohaus
215 Najoles Rd
Tel: 410-987-0130
Have I mentioned that I don't trust mechanics?
DP is offline
post #28 of 79 (permalink) Old 06-07-2009, 07:07 AM Thread Starter
DP
DP's Avatar
Nah, my oil is kosher so I am protected.
DP is offline
post #29 of 79 (permalink) Old 06-07-2009, 07:09 AM Thread Starter
DP
DP's Avatar
I have a spare computer and that didn't make a difference. The coil biznez will be checked today and if P100 is correct he will get the loot.
DP is offline
post #30 of 79 (permalink) Old 06-07-2009, 07:11 AM
Date registered: Apr 2009
Vehicle: 96 E-320, 91 190E, various and sundry Euro and American vehicles
Quoted: 2 Post(s)
Gee Drewprof.
Never heard that.(hate mechanics as well, but sometimes we get stuck)
Coil sounds like a good start, but try the water misting too. Even when things run fairly well, the arching can happen.
Aardvark
aardvark is offline
    Stalling Quiz: WINNER GETS $50 DP W201 190-Class 44 06-12-2009 09:00 AM
    ferrari quiz full house Off-Topic 14 09-21-2007 05:14 PM
    Quiz benzover C208/A208 CLK-Class 9 06-09-2007 08:28 AM
    This is a quiz bgoin W201 190-Class 3 07-01-2006 03:00 AM
    Easiest Quiz firstmb Off-Topic 2 02-24-2006 10:51 AM
