Intolerance, prejudice and hypocrisy alive and well in BWOT... - Page 28 - Mercedes-Benz Forum
post #271 of 342 (permalink) Old 06-01-2009, 11:02 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1040 Post(s)
Originally Posted by isthisdave View Post
So which carbon isotope did they use to date the 'lemur'? Or Lucy, for that matter?
Satan provided that one to throw us off and test our faith.
DP is offline
post #272 of 342 (permalink) Old 06-01-2009, 11:03 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 88 Post(s)
Originally Posted by 65red
Yes I understand that they use the surrounding sedimentary rock as well. But how do they date the rock??
Expand your horizons and broaden your base of knowledge.
It's easy.
Bones, Rocks and Stars, Chris Turney, Book - Barnes & Noble
isthisdave is offline
post #273 of 342 (permalink) Old 06-01-2009, 11:12 PM
DP
DP's Avatar
It's easy.
Yeah read the Bible
DP is offline
post #274 of 342 (permalink) Old 06-01-2009, 11:15 PM
Date registered: Jun 2008
Originally Posted by mcbear View Post
Why do you assume the algorithms only rely on constants?
It is not assumption. All of the accepted formulas rely on the half life of the isotope on which they are measuring. For carbon dating, the formula relies on the assumption that all living organisms contain the same ratio of carbon 12 to carbon 14, both today and 60,000 years ago. So there are two constants that are used, the ratio of carbon 12 to carbon 14 and the half life of carbon 14 which is assumed as 5730 years.
Interstingly enough, the supporter of carbon dating acknowledge the formula is not very accurate for anything that has died in the last ~60 years as the radiation from nucluear test and other types of radiation man has developed and tested has rendered the very inaccurate. So again, an assumption is drawn that modern day is the only time in history that the radiation levels have fluctuated.
All things to consider.
65red is offline
post #275 of 342 (permalink) Old 06-01-2009, 11:23 PM
DP
DP's Avatar
Something tells me you're in the oil industry
DP is offline
post #276 of 342 (permalink) Old 06-01-2009, 11:24 PM
I wish. I would be driving a Maybach instead of an MB...
65red is offline
post #277 of 342 (permalink) Old 06-01-2009, 11:27 PM
DP
DP's Avatar
Then you know nothing on how oil was originated? Do you believe it was dinosaurs?
DP is offline
post #278 of 342 (permalink) Old 06-01-2009, 11:51 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1551 Post(s)
It's 6000 year old primordial god-sauce
Zeitgeist is offline
post #279 of 342 (permalink) Old 06-02-2009, 12:03 AM
DP
DP's Avatar
Must have been a hell of a bukake party
DP is offline
post #280 of 342 (permalink) Old 06-02-2009, 12:11 AM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
So how does this mesh with numbers that go back 3.3M and 47M years if the constants +/-3 are only for 60K years? How does that deviation propagate back?
But the second question [and I suck at this part of science, by the way], you said that the only time in history that the radiation levels have fluctuated is modern but earlier you said that you didn't understand the application of a constant math formula on a wildly dynamic atmosphere.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
    Fear, intolerance, loathing, hipocrisy? Check Codes Off-Topic 16 05-21-2009 07:29 PM
    Sodomize Intolerance GeeS Off-Topic 14 11-02-2008 03:44 PM
    The Palin Hypocrisy FeelTheLove Off-Topic 14 09-19-2008 10:55 PM
    What is hypocrisy? runawayfreighttrain Off-Topic 45 08-17-2006 02:06 AM
    to all of your prejudice and racist people ashroxamg R170 SLK-Class 8 09-14-2001 10:30 AM
