I have come to a decision - Page 2 - Mercedes-Benz Forum
post #11 of 51 (permalink) Old 05-21-2009, 06:24 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
Originally Posted by p100 View Post
You do not want to tell that to disfigured cops who almost burned to death, or to families of those who did die, when the fuel tank ignited from being ruptured by the rear axle assembly when their car was hit from behind. That is why some police departments will not order these cars and this is why I will not own one. Mercury Grand Marquis has the same problem.
Wrong. The problem was not Ford's. The problem was the typical aftermarket issue cargo storage rack that nearly all municipalities used was screwed into the trunk wrong. The typical installation used sheet metal screws that would pierce the rear trunk wall and inadvertently point their ragged metal ends extremely close to the fuel tank. Everything was fine until a serious rear end collision could possibly push the sheet metal screws into the tank, possibly sparking a fire, or at least rupturing the tank. Why do you think the fires only happened to police cars and not civilian crowns and vic taxis? We handled a death case in Dallas many years ago involving the cop (an acquaintance of mine, and only 28 years old) being burned to death in a vic after being rear ended at 54 mph by a legally drunk dude in a Jeep Wrangler. We and everyone else found out the truth after this. The vic is still the #1 chosen police car, far over the Impala and Charger to this day. We own no less than 3 vics. It is the most quality you can buy used for the money. My mother and brother drive the vics regularly as do I. I have that much faith in the car.
Shane is offline
post #12 of 51 (permalink) Old 05-21-2009, 06:28 PM
Shane's Avatar
Originally Posted by drewprof View Post
I can't afford either one. If I had a choice, I would buy a NEW van but unfortunately teaching does not allow for luxuries.
You can get a nice one for less than $6k. This one will make everyone scamper within vision who has a warrant for their arrest. You can afford $6k can't you?
Ford : Crown Victoria:eBay Motors (item 150346755062 end time May-26-09 18:30:00 PDT)
Shane is offline
post #13 of 51 (permalink) Old 05-21-2009, 06:43 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1065 Post(s)
Even if I could, I won't! $6K to buy and $60K to keep it running... No way! No more used cars for me. I will go get a job now...
DP is offline
post #14 of 51 (permalink) Old 05-21-2009, 06:52 PM
Date registered: Feb 2007
Vehicle: 300SD
Quoted: 62 Post(s)
Ok, thanks for clarifying this. The story I heard on the news did not go into these details. These gruesome accidents, and not knowing the real reason for fuel tank ignition, kept me from buying one of these cars. I owned a 1975 Ford LTD back in the 80's and that car was a tank, including its fuel consumption.
p100 is offline
post #15 of 51 (permalink) Old 05-21-2009, 06:56 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
So the answer is to remove the rack and screws and drop the tank to in sure it is clear or if not, replace the tank? Is that the only issue?
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #16 of 51 (permalink) Old 05-21-2009, 06:59 PM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 425 Post(s)
What are you smoking??
That's a very good car right there and I'm certainly not generally a Ford fan. Beat the smell of bacon and doughnuts out of the interior and you'd be good to go for years.
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is offline
post #17 of 51 (permalink) Old 05-21-2009, 07:12 PM
Shane's Avatar
Yes. And you only need to do that if the police car was a regular patrol car, a vomit comet as they speak. You never want one of those anyway. You want a supervisor's car, as they are better treated, especially in small municipalities, and rarely get the trunk cargo holder. You can also get the the crown vic sport which gives you all the suspension pieces from a civilian.
Shane is offline
post #18 of 51 (permalink) Old 05-21-2009, 07:19 PM
Shane's Avatar
The same durability goes for a Town Car and a Grand Marquis. Any of the Panther platforms past around '99 are good to go. Just try to get the sport suspension option prior to '03 or you get a floaty ride. Bilsteins fix that though on the older ones. Look for factory true duals to signify the real ones. After you get the car get an aftermarket larger front roll bar. Nice, sticky, 16 tires and you will be amazed at the handling and ride comfort mix.
Don't waste your money on a new car. Don't buy a used car bargain either, there is typically a reason for the bargain. A certified used Lincoln Town Car maybe the safest way to go from the dealer. New Town Car buyers are usually old enough to know how to treat cars correctly. The younger crowd are self serving morons.
Did I mention the Panther platforms are easy to service?
Shane is offline
post #19 of 51 (permalink) Old 05-21-2009, 07:20 PM
Vehicle: 300SD
Quoted: 62 Post(s)
I think this is the only issue and as long as the car has not been in an accident, the rack (if present) can be removed and you are good to go. No damage to the fuel tank without a massive rear impact can occur.
The cars with the basic police package are rather spartan. They come with only AM/FM radio, no cruise control, vinyl floor covering instead of carpet, and vinyl rear seats. You get dual exhaust, higher rear axle ratio (lower gears), in some cases traction lock differential, heavy duty chassis, shocks, wheels, engine cooling and a heavy duty transmission.
I have seen almost new police package Crown Victorias on eBay that were ordered with other desirable options such as full capeting, CD player, cruise control, full body side moulding, cloth rear seats, etc. Apparently these are cars ordered for detectives or police chiefs, in some cases for FBI/CIA. They are just like a regular passenger Crown Victoria, except with heavy duty components. Especially the heavy duty transmission is something that you cannot get on a regular Crown Victoria.
There was a 2008 police package Crown Victoria with those nice options on eBay recently for something like $ 23k with only 1,200 miles on it. Some dealer in Texas specializes in these almost new police cars I believe. I think he buys them new from various agencies who order too many cars, and then he drives them for about 1,000 miles to sell them as used vehicles (maybe to get around some restrictions on sale of these cars brand new to public).
p100 is offline
post #20 of 51 (permalink) Old 05-21-2009, 07:29 PM Thread Starter
DP
DP's Avatar
Ok stop it with the Crown Vics it's burning my eyes!!!!!!!!!!!!!!
I will go to the poor house for a piece of ass, how hard is that to understand?
DP is offline
Decision Decision dwieden R170 SLK-Class 9 10-10-2008 05:21 PM
decision Panther201 W201 190-Class 4 01-06-2006 03:13 PM
Decision Sandro N C215 CL-Class 1 11-20-2005 12:28 AM
slk 55 or sl 500...decision...decision arlmed R171 SLK-Class 18 12-23-2004 08:33 AM
Decision Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-27-2002 08:07 AM
