Does anyone in here know about cars? - Page 2 - Mercedes-Benz Forum
post #11 of 61 (permalink) Old 05-20-2009, 07:48 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 572 Post(s)
I can't believe this is the first he's looking at the fuel pump though. I had to replace one of those on an '88 Trans-Am, and when it finally shit the bed, it acted almost exactly like the problems Drew's been describing.
Qubes is online now
post #12 of 61 (permalink) Old 05-20-2009, 07:51 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 103 Post(s)
Send a message via AIM to edfreeman
Naw, he put in a new fuel pump months ago.
edfreeman is offline
post #13 of 61 (permalink) Old 05-20-2009, 07:53 PM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 572 Post(s)
That's what I'd have thought.
Qubes is online now
post #14 of 61 (permalink) Old 05-21-2009, 09:57 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
Yep, relatively new pump!
I am living a nightmare with this car, maybe I will take Shane's offer after all.
DP is offline
post #15 of 61 (permalink) Old 05-21-2009, 11:47 AM
Date registered: Sep 2004
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 256 Post(s)
Drew,
My son is in the middle of converting his 1985 190E 2.3-16 (Euro version) from the Bosch CIS system to a VEMS sequential injection system. The VEMS system has an input port in the wiring harness for a fuel pressure sensor. While investigating the CIS system he discovered there is no pressure feed back to shut the pump off, it runs on a duty cycle of some predetermined timing, depending on throttle position and engine speed, apparently. This means if your check valve is not functioning correctly, or your filter is munged up, you may not always have the intended fuel pressure at that distributor device.
Just a thought.
Jim
EDIT: Another thought. Seeing you are missing your Butter Jesus and copper gutters, is there a chance they are in your gas tank? I had some asshole in Alaska put an 8-track tape in my VW Bus gas tank, and it took me a long time with really erratic operation to finally notice that when I took the carb off every night to disassemble and clean it, and get it ready to reinstall the next morning, there was something shiny in the little pipe nipple that the fuel hose attached to. I picked it out of there with a paper clip and then pulled about 300 feet of 8-track tape out. The spool may or may not have been in the tank, but once I got the tape out the problem was solved.
JimSmith is offline
post #16 of 61 (permalink) Old 05-21-2009, 11:55 AM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
It's time to upgrade and contribute to the 39mpg goal.
... and this important discussion continues.
Dooloogssst!
mlfun is offline
post #17 of 61 (permalink) Old 05-21-2009, 01:15 PM Thread Starter
DP
DP's Avatar
There is a ball in there?
DP is offline
post #18 of 61 (permalink) Old 05-21-2009, 01:40 PM
Quoted: 256 Post(s)
I used to have a "spare" in the shed but couldn't find it. But, yes, it has a spring and a ball. The pressure pushes the ball off the seat against the spring and when the pump shuts off the spring and stored pressure in the accumulator push the ball back against the seat. The ball is not loose, or shouldn't be, so shaking it should not make a rattling noise. I also believe the size of the fittings on each end are different so you can't actually put it in backwards.
Jim
JimSmith is offline
post #19 of 61 (permalink) Old 05-21-2009, 04:24 PM Thread Starter
DP
DP's Avatar
I have a spare one but it's hallow. The other one came with the fuel pump already attached so I didn't take it out to check while installing the pump.
DP is offline
post #20 of 61 (permalink) Old 05-21-2009, 04:29 PM
Shane's Avatar
Vehicle: 1957 219, 1967 250SE Coupe, 1969 280SE Convertible, 2017 C300 Coupe 4Matic
Quoted: 1780 Post(s)
I'm not ignoring your plight Drew, it is just that it could be so many things, that I don't want to lead you off on several wild goose chases. Hopefully it is the fuel pump, but somehow I doubt it.
Shane is offline
    Mercedes Sells their cars with only 70% of the cars real perfomance. joelsec W126 S,SE,SEC,SEL,SD,SDL Class 20 03-01-2011 12:06 AM
    why is mercedes making a computer cars rather than a good reliable cars that they are known for benz lover W126 S,SE,SEC,SEL,SD,SDL Class 9 05-19-2009 11:10 PM
    American cars more dependable than German cars! venk R170 SLK-Class 16 03-15-2004 02:39 PM
    how many people consider 4 door cars to be sports cars? I for one, DO NOT! RavER R170 SLK-Class 5 06-18-2001 06:24 PM
