WTF is wrong with the 190E? - Page 3 - Mercedes-Benz Forum
post #21 of 59 (permalink) Old 05-12-2009, 04:12 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Originally Posted by drewprof View Post
What clicking sound? I don't remember that!
This is the first time I ever heard this buzzing sound inside the cabin, behind the cluster once I get the engine going by keeping the throttle down. The car wouldn't start otherwise.
I read it on another forum, as I recall.
GeeS is offline
post #22 of 59 (permalink) Old 05-12-2009, 04:17 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
I have been in so many that it's not even funny anymore. I still don't recall a clicking sound, but maybe it was in reference to valve noises, I don't know, but I do I know is that this LOUD buzzing sound inside the dashboard is a first.
DP is offline
post #23 of 59 (permalink) Old 05-12-2009, 04:24 PM
Date registered: Feb 2007
Vehicle: 300SD
Quoted: 62 Post(s)
Most people who have older cars have problems with them. I too like to fix everything myself but I draw a line when I spend days troubleshooting something with no results, or have a job that requires a high lift and plenty of time. I too have been burned by incompetent mechanics, including the ones at our local Mercedes dealership. I took my 300SD to them because the A/C compressor would not come on. After several hours of trobleshooting I was told that I needed the auto temperature controller box for $ 1,200! They charged me $ 180 for the diagnosis and I left. I bought the same controller for $ 230 from an aftermarket source, installed it and nothing! Over $ 400 down the drain and no results! So I stated troubleshooting the system myself. I found the problem in less than an hour. It was the thermostatic switch in series with the main A/C switch. Very clearly shown on the schematic. All I had to do was jumper the switch out of the circuit and the A/C compressor immediately came on. The replacement switch cost less than $ 50 and it took about an hour to install it.
p100 is offline
post #24 of 59 (permalink) Old 05-12-2009, 04:26 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
No, is wasn't coming from under the hood, it was closer.
GeeS is offline
post #25 of 59 (permalink) Old 05-12-2009, 04:28 PM Thread Starter
DP
DP's Avatar
Well I did hear a hissing sound from the heating unit but that's not what I hear now.
DP is offline
post #26 of 59 (permalink) Old 05-12-2009, 04:31 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
No, you seemed to be describing a clicking noise as if a relay had failed. You don't remember? No wonder you can't fix it.
GeeS is offline
post #27 of 59 (permalink) Old 05-12-2009, 04:31 PM
Vehicle: 300SD
Quoted: 62 Post(s)
A 5 ft rattlesnake hidden in the engine compartment?
p100 is offline
post #28 of 59 (permalink) Old 05-12-2009, 04:35 PM Thread Starter
DP
DP's Avatar
Ah I remember! That's a single click! That happens when the engine shuts off. It's not in the cabin, it's the fuel pump that does that.
DP is offline
post #29 of 59 (permalink) Old 05-12-2009, 04:49 PM
Shane's Avatar
Vehicle: Taking my time on my ride
Quoted: 1795 Post(s)
Tell us again what the thing does when it stalls and when you can restart it.
Shane is offline
post #30 of 59 (permalink) Old 05-12-2009, 04:53 PM Thread Starter
DP
DP's Avatar
Well now it's screwed because I have the air mixture and EHA adjustments all off. Whatever I describe as the original stalling scenarios probably don't apply right now, specially with this buzzer business that sounds like a warning device of some sort.
Anyway, before I tinkered with the car, the car would stall randomly when I come to a stop such as a red light. It would also stall at start up.
DP is offline
    WTF is wrong with this country? Marsden Off-Topic 19 02-09-2009 03:27 PM
    my 190e top is 75mph.WTF? Illan W201 190-Class 22 03-04-2008 08:41 PM
    WTF?! Wrong Green Filters for my CLK55 Airbox ?!?! deyainrdy4ds C208/A208 CLK-Class 7 03-02-2007 07:59 AM
    SCAM MERCEDES BENZ DEALERS not giving LOANERS ANYMORE ? WTF IS WRONG WITH THAT ? max_benz W203 C-Class 19 02-02-2007 12:40 AM
    SCAM MERCEDES BENZ DEALERS not giving LOANERS ANYMORE ? WTF IS WRONG WITH THAT ? max_benz Off-Topic 26 01-24-2007 03:06 PM
