Question for you Carpenter Types - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 05-05-2009, 12:11 PM Thread Starter
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: '98 E320 Wagon (non 4matic)
Send a message via AIM to TNTRower
I am building a loft bed for my daughter.
As I want this to last through the years I am looking for a specific type of Bolt to hold the frame together. I would prefer to not use a regular lag bolt.
What I am looking for is a barrel sleeve type anchor. The sleeve would be threaded on the outside like a lag bolt, and then machine threaded inside to take a carriage bolt.
I have looked at the Home Depot and actually talked with the Grip-Rite representative in the fastener aisle. I can't seem to locate them online either. Mostly because I don't know what the proper name would be I think.
Anybody know what I am talking about or better yet know where I can get some?
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
If the Arabs put down their weapons today, there would be no more violence. If the Jews put down their weapons today, there would be no more Israel. --Benjamin Netayahu
TNTRower is offline
post #2 of 33 (permalink) Old 05-05-2009, 12:13 PM
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
Don't know about a lag bolt with a machine thread on the inside, but a T nut would work great for you. Here's a link:Tee Nuts | Fastener SuperStore
gerkebi is offline
post #3 of 33 (permalink) Old 05-05-2009, 12:20 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1472 Post(s)
I second the recommendation
Zeitgeist is offline
post #4 of 33 (permalink) Old 05-05-2009, 12:21 PM Thread Starter
TNTRower's Avatar
Thanks Gerkebi but those won't work for what I need to do. These are going to be the bolts that hold the bed frame and crossmembers together.
Here is a picture of the project. Where you see the two dots on the end is where I want to use these bolts. I am looking for bolts about 4-6 inches long.
Who's John Galt.
TNTRower is offline
post #5 of 33 (permalink) Old 05-05-2009, 12:48 PM
~BANNED~
Date registered: May 2008
Vehicle: MBZ 300SD
Oauuuu
A suspended loft bed would be cool.
Bolted on the ceiling.
AndreiRN is offline
post #6 of 33 (permalink) Old 05-05-2009, 12:51 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I know exactly what you mean, but I can't think of the name of them either.
However, I'm a fan of being able to more easily take something apart if need be (and you know your daughter will want to re-arrange things, right?) so I'd suggest either of the top two connectors in the attached PDF.
Check Codes is offline
post #7 of 33 (permalink) Old 05-05-2009, 01:01 PM Thread Starter
TNTRower's Avatar
That first one is actually not a bad idea. I will have to do some mortising but that shouldn't be too bad. I may see if I can't find something like those heavy duty ones.
I am a little leery of them though because I have seen them before (on the current bed) and they are ok for solid foundation type beds or panel partitions. I think they would work free with a simple frame. Although I could sink longer screws into the plates.
Who's John Galt.
TNTRower is offline
post #8 of 33 (permalink) Old 05-05-2009, 01:05 PM Thread Starter
TNTRower's Avatar
Originally Posted by AndreiRN View Post
Oauuuu
Sure it is cool.
This is a bed though that she will be able to take with her and pass down to her kids though. Assembled, disassembled, etc.
The frame itself is going to be pretty heavy, 2x10 with a 3/4 plywood insert for the mattress to be on.
I was looking at the Home Depot near me and the only 4x4 posts they had are the treated kind and cedar. I was thinking that cedar post might offset the pine frame.
Who's John Galt.
TNTRower is offline
post #9 of 33 (permalink) Old 05-05-2009, 01:19 PM
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
Did you ever think about using bed rail hangers instead? They hide on the inside of the frame so you keep a nice clean look on the outside, and disassembling the bedframe becomes a piece of cake - no tools required.
Bed Hardware - Workshop Supply :
D'oh. That's what Greg recommended. I'll shut up now.
jlomon is offline
post #10 of 33 (permalink) Old 05-05-2009, 01:38 PM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1384 Post(s)
Originally Posted by TNTRower View Post
Sure it is cool.
Not sure I'd use treated lumber for an indoor piece of furniture.
Is the "New" Pressure-Treated Lumber Safe? Woodworking Safety Tips
Scroll about halfway down on this one. It says outdoor use only.
http://www.naturalhandyman.com/iip/infxtra/infpre.html
Is CCA the abbreviation for Cancer Causing Agent?
http://www.ewg.org/node/25647
Quis custodiet ipsos custodes?
Digmenow is offline
    axle types Benzoid123 W123 E,CE,D,CD,TD,TE Class 14 04-13-2007 01:21 PM
    Steering Types mbeclass General Mercedes-Benz 9 10-18-2006 04:58 PM
    fuel types ed911 W126 S,SE,SEC,SEL,SD,SDL Class 1 09-06-2006 09:01 AM
    Unimog propane conversion from K.C. Carpenter ncmogger Unimog 1 07-28-2006 12:48 AM
    PICS of Different types of center caps (to answer Pize98's question) roadsession W163 M-Class 3 03-27-2005 01:34 PM
