Mechnical Questions - Page 2 - Mercedes-Benz Forum
post #11 of 39 (permalink) Old 04-06-2009, 10:02 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 95 Post(s)
If the IRS center section and the powerplant are both solid mount a single u-joint coupling was what I recall seeing on mid engine sand rails. Never engineered one so I've no idea of tolerances....
isthisdave is offline
post #12 of 39 (permalink) Old 04-06-2009, 10:08 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1069 Post(s)
Those are not really on my radar as I am doing a preliminary research. Right now I want to be able to mate a transmission to to differential in lieu of a an expensive Porsche/Ferrari like transaxal. I want to be able to build this thing from mostly junkyard parts as much as possible.
DP is offline
post #13 of 39 (permalink) Old 04-07-2009, 02:57 PM
Date registered: Feb 2008
Vehicle: 1987 420SEL
What the h*ll are you building?
Could you offset the two shafts and connected them via an industrial belt, or maybe something like a flat-link chain with robust sprockets? They use them on combines and such, it's basically a super-strong and low precision chain with cast steel gear sets.
I've coupled a transmission yoke right to a pinion yoke via a universal-joint spider, but it wasn't for anything to be used on public roads...
A MB-style flex-disc was mentioned; this seems like a good idea if you're looking not to destroy too many bearings during the service life of said go-cart/space capsule/bull-dozer.
I can't remember which car it was, but there was a production vehicle made by GM, I think, back in the 60's that used a flexible drive-shaft not unlike a very strong rotary-tool flex shaft; no U-joints! Maybe something like this would work?
Benz Prodigy is offline
post #14 of 39 (permalink) Old 04-07-2009, 03:23 PM
Stuantle's Avatar
Date registered: Jan 2008
Go to a junkyard and get a Porsche 924/944 transaxle. Back in the stone age we flipped a transaxle in a '65 Vair and mated up an old 283 mounted in the back seat with an engine cover out of a boat.
Stuantle is offline
post #15 of 39 (permalink) Old 04-07-2009, 03:24 PM
Stuantle's Avatar
You may be thinking of the old Dodge torque-tube.
Stuantle is offline
post #16 of 39 (permalink) Old 04-07-2009, 03:30 PM Thread Starter
DP
DP's Avatar
924/944 is not for mid engined configuration, not even rear engined.
DP is offline
post #17 of 39 (permalink) Old 04-07-2009, 03:31 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1636 Post(s)
Zeitgeist is offline
post #18 of 39 (permalink) Old 04-07-2009, 03:34 PM Thread Starter
DP
DP's Avatar
I am chopping a Fiero in half
The rear half will be all custom tubular with a V8 at 90 degrees with the rear axle.
The body will be something out of Mad Max... As hideous as I can get it!
DP is offline
post #19 of 39 (permalink) Old 04-07-2009, 03:34 PM
Stuantle's Avatar
Originally Posted by Zeitgeist View Post
Right you are! And I think it used half a V8 as a slant 4.
Stuantle is offline
post #20 of 39 (permalink) Old 04-07-2009, 03:36 PM
Stuantle's Avatar
Toronado.
Stuantle is offline
A few questions USF_Benz R171 SLK-Class 4 02-03-2009 03:26 PM
2 Questions Jason_604 W204 C63 AMG 1 01-12-2009 10:58 AM
1992 400E rust repair questions, and general restoration questions Zack1978 W124 E,CE,D,TD Class 6 10-04-2008 07:02 PM
More C230 Questions.. This Owners manual makes no sense...Lighting questions..HELP.. Blackvette W203 C-Class 3 02-19-2008 05:17 AM
Some questions DarkManX4lf W123 E,CE,D,CD,TD,TE Class 6 09-12-2006 06:00 AM
