Anyone online with satellite dish know-how - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 03-30-2009, 04:37 PM Thread Starter
Hal Adams's Avatar
Date registered: Oct 2007
Vehicle: 07 SL350, 14 BMW320, 05 SLK and 4.6 MGBV8
I am in a bit of a panic.
Putting up my TV satellite dish tomorrow - I thought on a wall just above where the TV is, but just been told by she-who-must-be-obeyed, that no, it will ruin the look and I have to put the dish at the back of the house...
Question is: Using good quality double or triple screened co-ax without any joins, what is the maximum distance run without loss???
Help before morning would be warmly welcomed!!
Hal Adams is offline
post #2 of 18 (permalink) Old 03-30-2009, 04:44 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
You have no choice but to use a cable; you're screwed! Do not fight the "force", that is the nature of things.
DP is offline
post #3 of 18 (permalink) Old 03-30-2009, 04:46 PM
DP
DP's Avatar
Oh, you may want to boost the signal before you split the wires anywhere down the line. Get an inline signal booster that actually plugs to an outlet, it's basically an amplifier.
DP is offline
post #4 of 18 (permalink) Old 03-30-2009, 04:49 PM Thread Starter
Hal Adams's Avatar
Thanks for being here!!
Appreciate I have to use a cable, but how long can the cable be before I need amplifiers do you reckon?
My problem is that to get to the new position from the TV, I have to go around three sides of the house...
post #5 of 18 (permalink) Old 03-30-2009, 04:57 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Do you have an attic? I'd bring the cable in through an eave and then amp it right there, shoot some expanding foam around the hole for the cable. You'd have to wire an outlet up there but then you're inside and don't have to go around the house.
If you don't have an attic...hmmm. Crawl space? If neither, buy the cable the ength you need and just drag it in the house to the TV, see what reception is without the amp and before you string it. Perhaps it will be acceptable (for some reason 100M is sticking in my head) and if not perhaps SWMBO will be swayed by the cost of a weatherproof outlet and connection installed by the new location?
Take care and enjoy the (amplified) ride,
Greg
Check Codes is offline
post #6 of 18 (permalink) Old 03-30-2009, 05:01 PM Thread Starter
Hal Adams's Avatar
No, no attic, the cable has to run up under the gutter pipes.
If you think 100M is ok, then I am ok, as it is only 30M, 40 max...and it will be triple screened.
I will sleep happy!
Thanks Greg!
post #7 of 18 (permalink) Old 03-30-2009, 07:05 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 103 Post(s)
Send a message via AIM to edfreeman
Go to Best Buy and ask for Monster Cable. They'll fix you up.
edfreeman is offline
post #8 of 18 (permalink) Old 03-30-2009, 07:27 PM
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: '98 E320 Wagon (non 4matic)
Send a message via AIM to TNTRower
Anything under a 100m is fine.
You get severe signal degradation when you start employing splitters. Basically try and keep your LNB's "One per TV" and you won't have an issue. If you have 2 TV's it is better to have 2 LNB's. If you have four TV's then 4 LNB's. If you go over that then invest in cheap line amplifier. They have 'em at Home Depot, Radio Shack, Lowes, etc.
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
If the Arabs put down their weapons today, there would be no more violence. If the Jews put down their weapons today, there would be no more Israel. --Benjamin Netayahu
TNTRower is offline
post #9 of 18 (permalink) Old 03-31-2009, 12:29 AM Thread Starter
Hal Adams's Avatar
Thanks Guys,
i am about to start stringing the co-ax now and hope to have true HD tonight!
Yes, I am only putting one TV on the LNB without any splitters etc.
post #10 of 18 (permalink) Old 03-31-2009, 01:30 AM
TNTRower's Avatar
Originally Posted by Hal Adams View Post
Thanks Guys,
Only if you subscribe to their HD Signal.
Who's John Galt.
TNTRower is offline
    CF look for the dish and the molding nightOWL R171 SLK-Class 3 01-22-2008 03:10 AM
    Satellite Dish in Tehran Teutone Off-Topic 12 06-14-2006 09:35 AM
    Listen to Howard Stern's First Satellite Broadcast For Free Online firstmb Off-Topic 1 01-08-2006 07:09 AM
