A Question About Ram? - Page 3 - Mercedes-Benz Forum
post #21 of 44 (permalink) Old 03-18-2009, 06:54 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1065 Post(s)
Originally Posted by Zonet View Post
No seriously guys... c'mon please, I'm looking at the site now, I'm confused... anyone that knows about technical IT here?
DP is offline
post #22 of 44 (permalink) Old 03-18-2009, 07:00 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 112 Post(s)
Send a message via AIM to edfreeman
I love these tech threads.
BTW, which browser, Safari or Opera?
edfreeman is offline
post #23 of 44 (permalink) Old 03-18-2009, 07:02 PM
Forum Administrator
RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1583 Post(s)
Assholes... C'mon one of you must know about Ram, I mean, most of you here are post junkies... Like 20k+ yet know nothing about PC's?
I just drive 'm. I don't know what makes 'em go.
Quis custodiet ipsos custodes?
Digmenow is offline
post #24 of 44 (permalink) Old 03-18-2009, 07:03 PM Thread Starter
Zonet's Avatar
Date registered: Nov 2008
great... thanks guys.
Originally Posted by Stryker-1999 S600 View Post
the comparison between a V8 and a V12 isn't a decision, it's an opportunity.
Zonet is offline
post #25 of 44 (permalink) Old 03-18-2009, 07:04 PM Thread Starter
Zonet's Avatar
Originally Posted by drewprof View Post
Ok ok... Now that was funny!
Zonet is offline
post #26 of 44 (permalink) Old 03-19-2009, 09:11 AM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 223 Post(s)
Which one is better overall:
- 4x1GB DDR2 800Mhz
- 2x2GB DDR2 800Mhz
I would think the 4 x 1 GB 800 MHz would, considering each ram card has 800mhz, that’s more than the 2x2gb 800mhz. Because it’s either 800x4 or 800x2. Basically, each gig will run at 800 MHz of speed if I chose the 4x1 set up, the 2gig set up will run 2gigs at 800 MHz.
Correct?
The speed of the two configurations are the same at 800MHZ with the same 4GB total RAM. The 2x2GB configuration is more advantageous (faster) because it only occupies 2 memory banks (instead of 4 with 4x1GB.) As such, the CPU would search for data within 2 memory banks instead of 4. Which, in turn makes the calculation a little faster.
Hope this help.
edcarls is offline
post #27 of 44 (permalink) Old 03-19-2009, 09:14 AM Thread Starter
Zonet's Avatar
Hope this help.
Wow... Wooow.... WOW! somebody ACTUALLY gave a mature reply! Thank you guy!
PS: It's a Q6600 3.0ghz - Will it still be a problem? 4x1gb of course. I just heard they run better transfering 1GB of data at 800mhz instead of 2GB at 800mhz.
Zonet is offline
post #28 of 44 (permalink) Old 03-19-2009, 09:15 AM Thread Starter
Zonet's Avatar
^^ Better off, someone actually replied to the question.
Zonet is offline
post #29 of 44 (permalink) Old 03-19-2009, 09:31 AM
Quoted: 223 Post(s)
3.0ghz is the speed of your processor (CPU), 800mhz is the speed of your RAM and GB is size of the RAM. In your case the overall speed (or Transfer rate) is 800mhz on both 1GB or 2GB. The 2GB transfer rate may be a bit slower if the configuration is 2x1gb meaning 2 1GB's occupies 2 memory bank.
The speed difference is barely noticeable unless you are using it for CAD or other Graphic authoring application.
edcarls is offline
post #30 of 44 (permalink) Old 03-19-2009, 09:36 AM Thread Starter
Zonet's Avatar
^^ thanks the reply. The only reason I mentioned the CPU is becuase you said that the CPU man be used trying to search the ram slots etc etc. Thats why I asked if it will be a problem.
anyways, what do you suggest out of the three? Kingston ValueRAM, Transcend or Crucial?
Zonet is offline
Resealing Tip Ram treebogan Unimog 1 07-18-2012 09:30 AM
E-Ram Air Intakes Ivan820 W201 190-Class 15 10-04-2008 06:50 AM
Bonnet Ram SLK170 antmez R170 SLK-Class 1 07-09-2008 07:43 AM
RAM air intake supermoose W201 190-Class 4 06-29-2004 09:58 AM
Leaking hydraulic ram Fanger R170 SLK-Class 4 03-23-2004 04:43 PM
