I need... - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 02-26-2009, 09:19 AM Thread Starter
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 564 Post(s)
I need...
...30 pounds of lead ballast for the new kart we bought, stat. The preferred method of fastening is to bolt them / safety wire them to the fiberglass seat, where placement can affect handling characteristics greatly.
Thoughts?
Qubes is offline
post #2 of 18 (permalink) Old 02-26-2009, 09:20 AM
Shane's Avatar
Vehicle: 1967 250SE, 1969 280SE Cab., 2017 C300 Coupe 4Matic
Quoted: 1768 Post(s)
Judge Smells says...
"You'll get nothing and like it!"
Shane is offline
post #3 of 18 (permalink) Old 02-26-2009, 09:24 AM
Brentwood MB
Guest
Posts: n/a
Quoted: Post(s)
Post
Just a thought, An old friend of mine who used to race, when he needed added weight he had long tubes full of #2 buckshot pellets that he strapped to his seat. The tubes were canvas I believe. He then could add or pour out the pellets to make the correct weight.
post #4 of 18 (permalink) Old 02-26-2009, 09:27 AM
Shane's Avatar
What does a used fag weigh? Anyone? Anyone? Bueller?
Shane is offline
post #5 of 18 (permalink) Old 02-26-2009, 10:59 AM Thread Starter
Qubes's Avatar
Vehicle: '08 C219
Quoted: 564 Post(s)
There's so little "seat" to put anything on that I'm not sure how I could make that work. Putting the stuff into the frame rails was discouraged because it shifts around too much, and adversely impacts handling. Ugh.
Qubes is offline
post #6 of 18 (permalink) Old 02-26-2009, 11:09 AM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 88 Post(s)
Maybe you can get a lead suit in your son's size....
isthisdave is offline
post #7 of 18 (permalink) Old 02-26-2009, 11:16 AM
Stuantle's Avatar
Date registered: Jan 2008
A daily diet of a slab of pork ribs covered in Sweet Baby Ray's washed down with a few beers of your choice followed by a half gallon of ice cream (again your choice). Lather, rinse, repeat. Your arse will swell up 30lbs in no time at all!
Stuantle is offline
post #8 of 18 (permalink) Old 02-26-2009, 11:19 AM
Brentwood MB
Guest
Posts: n/a
Quoted: Post(s)
Post
How about making up a money belt type holder for the Lead shot. The boy could wear it around his waist.
post #9 of 18 (permalink) Old 02-26-2009, 11:58 AM Thread Starter
Qubes's Avatar
Vehicle: '08 C219
Quoted: 564 Post(s)
I think I can get some diving weights to borrow. Will just have to figure out how to attach them. Long term I'm going to need something I can clamp to the kart rails or the seat.
Hoo boy.
Qubes is offline
post #10 of 18 (permalink) Old 02-26-2009, 12:35 PM
Date registered: Sep 2004
Vehicle: 2014 E250 Bluetec 4-Matic, 1983 240D 4-Speed
Quoted: 256 Post(s)
I think clamping to the lowest structural members of the cart is likely the best option. Are any of the structural items square or round tubes? You might consider filling them with lead shot. Drill a hole, pour the stuff in and then plug the hole with a bolt. The lower the better and if you have time, you can try shifting the distribution of weight from side to side for different courses.
If you want to lock it in to specific areas, you can try drilling a hole at one "stop" point, and squirting in some of that expanding foam insulation, then drilling another hole at the other "stop", pouring the stuff in and lifting the tube so the shot runs down to the foam, and when it is all in, you squirt some more foam in to make the other stop. Shot is trapped and if you want to take some out, drill a hole and pour it out, then seal it with a bolt.
Jim
JimSmith is offline
