My W126's Shedmate (Old Toyota) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-24-2009, 03:39 AM Thread Starter
Panzerkampfwagen CXXVI's Avatar
Date registered: May 2008
Vehicle: '88 500SEC HV, '84 7MA61 Supra, '83 JZA61 Supra
Well this has been my labour of love for the last 3 or 4 years.
It's a 1984 Toyota Supra... Originally a 2.8l SOHC 6 (5M, 103kW)... pretty lame, but the 7M uses the same block etc so very easy swap in.
Suspension wise, it's very similar to the W126 in the rear, with diff and rear suspension the same design.
It is a daily driver but I try to see the track when I can. I've spent heaps on it, and am looking forward to finishing it and spending dough elsewhere.
It has blown 4 headgaskets, prompting the full rebuild. Should never blow again....
I tried to modify it "In it's era", with no rice or things that look out of place on an 80s car. Don't want any rice or bling or that crap.
Well I bought it like this, with a 7MGTE I6 DOHC 3000cc Turbo and full 3" exhaust from the turbo back.
I put the unpainted front nosecose back on for RWC and rego.
Then it blew it's 3rd (this one being metal) headgasket.
After some time someone decided it was cool to run into me.
Thankfully for insurance, it then looked nice!
Then I added a bigger intercooler and Ed's old brake and wheel pack:
Then it had all the paint and interior ripped out, and became this:
Then after three years, at Sandown Raceway (Melbourne) the 4th headgasket went on the back straight at just over 200km/h.
So the engine was (is being) fully rebuild w/ forged pistons and a full balance. New everything... Plus I did most of the work myself which was great fun.
1984 Toyota Supra
W58 5 speed
New Engine specs:
2990cc 7MGTE
Arias Forged Pistons (Std size)
ARP Head Studs
ARP Rods Bolts
8.4:1 Compression ratio
Fully balanced pistons, crank and rotating assembly
Cometic Multilayer metal headgasket
Gates Racing Timing Belt
ACL Race series bearings
New Timing belt idler and tensioner pulleys
New Water pump
600x300x76mm intercooler
2.5" flowed aluminium piping
aluminium Cold air induction in box in front guard
Full 3" exhaust and dump pipe
Some sort of super-Exedy clutch
7MGTE flywheel redrilled, dowelled and balanced to fit
Custom throwout yolk and assembly
Speco Boost, Oil pressure and Oil Temp, mounted in din position....
Greddy Profec B @ 12psi
Standard AFM
RC Engineering 550cc injectors
Highflowed CT26E Turbo
Bosch Blow off Valve
Old engine made
227rwkW @ 5830rpm
550Nm @ engine
Hoping to crack 600Nm on 16psi on the new engine.
Rolling stock:
Polyurethane bushes
Tokico shocks
King Springs
17x7.5" +0ET BBS deep dish wheels
Front and Rear Whitelight adjustable swaybars
Truetrac 3.9 LSD diff
New and balanced tailshaft
Brake and Suspension setup:
Front Brakes:
MS65 Front hubs
326mm Brembo Rotors
4-piston Alloy Calipers
RA60 Strut tubes for 2deg. Negative camber
Rear Brakes:
MS123 Rear hubs
308mm UZZ30 Soarer rotors
2 piston GTR calipers
Custom setup for stock handbrake
Swap for Black stripey interior
Momo Course steering wheel with custom celica dragon badge
Custom new gearboot
Colour change to Black
Internal aerial
3.0 turbo badge on grille
3.0i decal on rear of car
Windows tinted dark as legal
Fully engineered and legal
What is left to do:
Haltech E11v2
Stiffer springs
... r spec tyres?
thats it.
Thats all i can think of at the moment. Opinions, criticisms and suggestions all welcome.
A 126rwkw dyno video:
Here are all my other videos of the car. All of which were done on the racetrack or a private road. I am not a hoon..... .
YouTube - Broadcast Yourself.
And a few before and after interior and engine bay pictures:
So I suppose you can see why I want a widebody W126 SEC Now!
'88 W126 500SEC HV Rauchsilber | '84 Toyota MA61 Supra - 600Nm | '12 Toyota ZN6 86 GTS - Coming soon
Panzerkampfwagen CXXVI is offline
post #2 of 2 (permalink) Old 02-24-2009, 05:27 AM
Date registered: Mar 2008
Kick ass car!
2JZ swap???
BryanW163 is offline
    W126's in movies Braando W126 S,SE,SEC,SEL,SD,SDL Class 19 11-28-2012 05:10 PM
    Diesel W126's THEROG W126 S,SE,SEC,SEL,SD,SDL Class 11 06-28-2007 05:35 PM
    1992 W126's Fulcrum525 W126 S,SE,SEC,SEL,SD,SDL Class 12 06-04-2005 05:11 AM
    those looking for v8 w126's Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 9 03-09-2005 07:16 PM
    Rare W126's cnd W126 S,SE,SEC,SEL,SD,SDL Class 0 03-03-2004 02:50 AM
