This is an outrage - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 02-07-2009, 12:47 PM Thread Starter
Date registered: Feb 2007
Vehicle: 300SD
Quoted: 62 Post(s)
This is an outrage
So after 18 electrocution deaths of our servicemen in Iraq, KBR is getting another $ 35 million contract to built another abomination in Iraq? If you did not know, KBR was until recently a subsidiary of Halliburton. And as for the Army Corps of Engineers, please note that Dick Cheney is no longer the Vice president, so somebody other than Halliburton or its former subsidiaries can now be awarded contracts in Iraq. You do not have to suck up to Cheney anymore. What a crock.
http://www.msnbc.msn.com/id/29065911
p100 is offline
post #2 of 8 (permalink) Old 02-07-2009, 01:24 PM
ogrenutz's Avatar
Date registered: Dec 2006
Vehicle: '81 300GD Cabrio, '78 450 SEL 6.9 Rocketship, Rover HSE
They weren't required to follow US building and electrical codes? Wonder whose specifications they were using? I'd say if the system was installed as specified, it's the designer's problem. But, if KBR deviated from the design, they're going to have to be punished for it. Maybe the designer and the installer are one in the same in this case. Who knows?
"Truth passes through three stages. First, it is ridiculed. Second, it is violently opposed, and third, it is accepted as self evident"-Arthur Schopenhauer
ogrenutz is offline
post #3 of 8 (permalink) Old 02-07-2009, 02:15 PM
Shane's Avatar
Vehicle: 1967 250SE, 1969 280SE Cab., 2017 C300 Coupe 4Matic
Quoted: 1768 Post(s)
^keep up the apologies... keep 'em up.
Shane is offline
post #4 of 8 (permalink) Old 02-07-2009, 02:25 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 88 Post(s)
The Pentagon procurement managers responsible for the continued use of KBR should be required to shower in KBR built equipment, in Iraq.
isthisdave is offline
post #5 of 8 (permalink) Old 02-07-2009, 02:29 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
Let's just get the obvious question out of the way right now. Why would they go to the extra expense of building to US Code while in IRAQ?
Charge for it, YES. Build to it...good luck with that. Those are facilities that are just for soldiers.
Look on the board and management structure of KBR and look at Republican donations to Congressional candidates and Presidential candidates. I believe you will find many of your answers.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #6 of 8 (permalink) Old 02-07-2009, 02:31 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1037 Post(s)
They used our servicemen as labor? Why am I not surprised?
DP is offline
post #7 of 8 (permalink) Old 02-07-2009, 03:23 PM Thread Starter
Vehicle: 300SD
Quoted: 62 Post(s)
The problem is not what code it was built to, but shoddy workmanship resulting in inadvertent grounding of hot electrical wiring. I do not believe that any civilized country on earth has an official electrical building code that when followed, would create conditions for an accidental electrocution while showering.
p100 is offline
post #8 of 8 (permalink) Old 02-07-2009, 04:02 PM
yoseyman's Avatar
Date registered: Nov 2005
Vehicle: Baby
Why do you think they were trying to get Joel over there? Hmmm.
yoseyman is offline
    this is an outrage Shane Off-Topic 8 01-29-2009 04:29 PM
    What an outrage! Nutz 4 Benz Off-Topic 1 04-25-2007 05:58 PM
    Trolling for outrage Botnst Off-Topic 10 04-02-2007 07:06 PM
    No Outrage from the Right? mcbear Off-Topic 28 02-16-2007 09:57 AM
    Where's the outrage? Botnst Off-Topic 13 02-05-2007 03:19 PM
