Engine noise question--in my Jeep. - Page 2 - Mercedes-Benz Forum
post #11 of 40 (permalink) Old 01-16-2009, 06:23 AM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 539 Post(s)
Doesn't sound like it's engine-related specifically, but I'm curious to hear what happens when you do a "dyno pull" in park. If you do not hear it under full throttle acceleration until 50kph, I seriously doubt it's anything combustion-related. Which means it's something with the drivetrain behind the motor or at the wheels.
Qubes is offline
post #12 of 40 (permalink) Old 01-16-2009, 08:42 AM
Date registered: Mar 2008
I found your problem!
BryanW163 is offline
post #13 of 40 (permalink) Old 01-16-2009, 09:01 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1003 Post(s)
Looks like that was a mattress
DP is offline
post #14 of 40 (permalink) Old 01-16-2009, 09:05 AM
Yep, a guy ran over it and kept on driving, said he felt a vibration.
post #15 of 40 (permalink) Old 01-16-2009, 09:28 AM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 539 Post(s)
That would suck.
Qubes is offline
post #16 of 40 (permalink) Old 01-16-2009, 10:04 AM
mzsmbs's Avatar
Date registered: Sep 2004
Vehicle: 1972 Mercedes 250 (/8) W114/M130
that's my thought too. if it was the engine, the noise would be there from the start. i don't see why the lifters and such would only make the noise at 50mph or whatever makes no sense..
so, dump the heep and get something worthy instead.
in political asylum
mzsmbs is offline
post #17 of 40 (permalink) Old 01-16-2009, 10:06 AM
Qubes's Avatar
Vehicle: '08 C219
Quoted: 539 Post(s)
^ I was going to get there eventually. The primary issue with the truck - my opinion - can be found on the front, back and sides, where it says "Jeep".
Qubes is offline
post #18 of 40 (permalink) Old 01-16-2009, 01:48 PM
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
That's why I only run over Select Comfort mattresses.
gerkebi is offline
post #19 of 40 (permalink) Old 01-16-2009, 02:19 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
I was thinking: varies w/ engine RPM -> combustion or valve train related (possibly connecting rod of cracked piston in Worst Case)
Varies with vehicle speed: Drivetrain related -> U-joint, tire / wheel problem, something wrapped onto the shaft or axle, or balancing weight on d-shaft gone missing.
It's a Jeep, maybe it ran over something while off-road?
However someone once told me that jeep was actually an acronym for Just Empty Every Pocket.
RadioTek is offline
post #20 of 40 (permalink) Old 01-16-2009, 02:24 PM
Shane's Avatar
Vehicle: 1967 250SE, 1969 280SE Cab., 2017 C300 Coupe 4Matic
Quoted: 1768 Post(s)
We're all jumping ahead until we know whether it is engine or drivetrain related.
Shane is offline
    SL500 Engine Noise Question tankrr R129 SL-Class 29 03-15-2016 02:55 AM
    Road Noise/Engine Noise..PROBLEM FOUND Satch0922 W210 E-Class 25 08-06-2015 02:53 PM
    JEEP CJ6 PROJECT, MOG 421 suspension travel & engine swap options. Frank-cj421 Unimog 5 05-14-2007 02:03 AM
    Engine noise question/Second opinion (long, sorry) b320 R170 SLK-Class 8 06-16-2006 07:59 AM
    MB newbie engine noise question Dave W163 M-Class 7 11-10-2002 11:02 AM
