Acid influx - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 01-04-2009, 11:55 AM Thread Starter
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1472 Post(s)
Acid influx
Yikes, I did a really bone-headed thing last night. The battery died on my Audi, so I put it on the charger at the 35 amp setting, then promptly forgot the whole thing and let it sit overnight. I just went out there and smelled sulfur pretty strongly. The battery sits under the rear seat and there was steam and hissing coming out from under there. I'm a bit freaked out, 'cause there's moisture all over the under seat area, which also houses most of the car's ECUs and such. I think I should try to discharge the battery before I disconnect the cables, but I'm afraid to turn the ignition on with all that moisture and overvoltage. It really looks like that thing could blow at any moment. I'm thinking of neutralizing the moisture/acid(?) with baking soda. Any thoughts or experience with this?
Zeitgeist is offline
post #2 of 22 (permalink) Old 01-04-2009, 12:02 PM
~BANNED~
Vehicle: 2002 clk320
Let it sit for a few days and everything will be alright, Trust me I know.
the clk man is offline
post #3 of 22 (permalink) Old 01-04-2009, 12:18 PM Thread Starter
Cruise Control
Zeitgeist's Avatar
Unfortunately, that's not an option. I have to move the car so the construction guys can work on my shop. Thankfully, it appears that the moisture under the seat is in fact just condensation and not acid--wheeiuwww!
post #4 of 22 (permalink) Old 01-04-2009, 12:26 PM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 271 Post(s)
Shart?
Over-voltage is a danger from a faulty alternator/rectifier. Each cell of the battery has an absolute maximum output of about 2.15 volts, irrespective to how much/long it has been charged.
You do however want to avoid any ignition source in the vicinity of the battery until it has finished gassing and cooled. Hydrogen/air at certain ratios is spectacularly explosive.
The condensate is almost certainly acidic* - taste each patch of it it. Make up a solution of bicarbonate of soda and sponge the whole area thoroughly. If left, the concentration of the acid increases as the water evaporates.
The battery may well be toast. Is it possible to determine the level of electrolyte left in it?
*On reflection, I think 'sealed' batteries have a system to retain H2SO4 fumes, but taste the damp patches anyway.
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is offline
post #5 of 22 (permalink) Old 01-04-2009, 12:36 PM Thread Starter
Cruise Control
Zeitgeist's Avatar
Well, the only reason I thought that it wasn't acid, is that it didn't fizz when I sprinkled baking soda on it. You're right, it no doubt is acidic. I dropped some soda on the top of the battery and that stuff went berzerk. Frankly, I'm scared to even get close that the boiling hissing tinderbox right now. That battery is a goner, for sure. The fuckin' car smells like an outhouse, too.
Whudda dumbshit
post #6 of 22 (permalink) Old 01-04-2009, 12:57 PM
Quoted: 271 Post(s)
I'm surprised your charger delivers 35 amps for charging. Did you borrow it from TK?? Are you sure that's not the cranking 'boost' setting? 10 amps is considered high for a car battery, with 3-5 amps recommended under most circumstances. At 35 amps you are delivering just about 500 watts. Think of the heat produced from 5x 100 watt bulbs.
post #7 of 22 (permalink) Old 01-04-2009, 01:04 PM Thread Starter
Cruise Control
Zeitgeist's Avatar
It's a big charger. Has a 35amp "fast charge" and a 200amp "start mode". Imagine if I'd left it on in the latter setting--wowza, that would be a mess! I should've used the 2amp trickle mode. I really need to step up to the models with a built in timer.
post #8 of 22 (permalink) Old 01-04-2009, 01:31 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Here's a possible solution...
Don't believe everything you think
Jayhawk is offline
post #9 of 22 (permalink) Old 01-04-2009, 01:34 PM
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
I've done the same thing. I fried one overnight at regular charge in my MG (actually two, it takes two 6v in series. What a friggin' mess.)
You're doing the right things now...baking soda everywhere, scrub it in good. I'd take the battery out as soon as things calm down, clean everything up good and dry and put a new one in. Wear latex gloves (I get them by the box at Rite Aid.) Don't forget to find your radio code.
gerkebi is offline
post #10 of 22 (permalink) Old 01-04-2009, 02:08 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 539 Post(s)
Anything else you want to share with us?
Qubes is offline
    Citric Acid Denver W126 S,SE,SEC,SEL,SD,SDL Class 11 09-13-2008 07:40 AM
    Acid flashback ThrillKill Off-Topic 2 02-18-2007 10:12 AM
    Acid Testing for the E-Class Curacao W211 E-Class 2 06-23-2006 09:38 AM
    Acid rain 420 SE Detailing and Car Care 18 10-24-2005 02:06 PM
    stains, acid rain? jmgnunez Detailing and Car Care 4 12-19-2003 12:43 AM
