Flo Control Valve - Mercedes-Benz Forum
post #1 of 43 (permalink) Old 12-19-2008, 03:27 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
Flo Control Valve
Anyone knows about Flo Control Valves? Like the Bell & Gossett kind but I am not sure what my brand is. My model number is FA3-61, it's a straight angle pattern with 2" on the angle met with a what I believe a 3/4 (that connects to the expansion tank). On the horizontal 2" outlet, I have a flange assembly.
Here is a sample (none look exactly like mine)
DP is offline
post #2 of 43 (permalink) Old 12-19-2008, 04:09 PM
FeelTheLove's Avatar
Date registered: Sep 2004
Vehicle: 83 Astral Silver 280 SL
Quoted: 8 Post(s)
Man, another bout of heavy drinking again bedevils this man.
Recall that earlier generations faced down fascism and communism not just with missiles and tanks, but with sturdy alliances and enduring convictions. They understood that our power alone cannot protect us, nor does it entitle us to do as we please. Instead, they knew that our power grows through its prudent use; our security emanates from the justness of our cause, the force of our example, the tempering qualities of humility and restraint.
-President Barack Obama, 1st Inaugural address
FeelTheLove is offline
post #3 of 43 (permalink) Old 12-19-2008, 05:55 PM
Pop
Pop's Avatar
Date registered: Dec 2006
Vehicle: 2007 E320 Blutec, 2004 Dodge 2500 HD Cummins diesel
Not sure what your question or concern is re. flow control valves. They are used extensively in the chemical/process industry. Generally speaking, they are used with a pneumatic or electronic operator to adjust the downstream flow of liquids. Perhaps many more applications as well.
Pop is offline
post #4 of 43 (permalink) Old 12-19-2008, 06:01 PM Thread Starter
DP
DP's Avatar
My application is my heating system. I have a hydronic system.
These valves are also called gravity or zone valves by some. In my case they allow for the flow of hot water upstream to the upper floors where my pump motor is on the downstream circuit on the return feed to the boiler.
I have two of those valves but one is rusted badly at the flange. I don't want to go through the trouble of cleaning it and resurfacing it if the price for a new valve is reasonable.
DP is offline
post #5 of 43 (permalink) Old 12-19-2008, 06:08 PM Thread Starter
DP
DP's Avatar
I got a Château Mauvais bottle of wine chillin for my consumption tonight. I would send you a sample in exchange for one of your exotic products.
DP is offline
post #6 of 43 (permalink) Old 12-19-2008, 06:21 PM
Pop
Pop's Avatar
Rusty flanges indicate that the joint has been leaking. While I am not familiar with your system, it appears that the valves simply act as check valves to allow flow in only one direction to keep the upper level piping flooded. It would certainly not hurt to clean up the valve and install new flange gaskets and see if it stops leaking. The cleaning is free if you do it yourself and the gaskets can be handcut from the correct sheet material if inexpensive replacement gaskets are not readily available. Be sure to reinstall it in the same orientation (look for an arrow on the body to indicate the direction of flow). Good luck!
Pop is offline
post #7 of 43 (permalink) Old 12-19-2008, 06:24 PM Thread Starter
DP
DP's Avatar
Yes all that make sense but I was hoping to find a new one because I have a feeling that once I fiddle with the flange it's going to crack in pieces. It just looks bad.
DP is offline
post #8 of 43 (permalink) Old 12-19-2008, 06:31 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
Since it is winter, is this valve going to be open/shut with regularity until spring when you shut down the system?
In other words, could you take the valve out of the system for the winter and run a straight copper [sorry] fitting while you do a search for the correct control valve?
And can you post pics?
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #9 of 43 (permalink) Old 12-19-2008, 06:52 PM
mcbear's Avatar
Vehicle: E500Es
The Framework Agreement number lines up with FA361 which is Atlantic Plastics - 020 888 44 388 out of England which is part of Tyco Flow Control.
Tyco Waterworks
It might be a wild goose chase since the tyco site sucks but it is worth a shot. Their search "feature" is less than optimal.
McBear,
Kentucky
mcbear is offline
post #10 of 43 (permalink) Old 12-20-2008, 01:36 PM Thread Starter
DP
DP's Avatar
What a friggin mess!
I am right now taking a break from this job. I went ahead and supposedly drained the system from water but I forgot about the expansion tank
When I finished cutting the last bolt on the flange I got drenched and basically turned the basement into a pool. Anyway, I just finished cleaning up and my next job is to drill out the bolts from the flanges. They did not want to come out or cooperate; one had its head fused to the flange as if the metals combined and no amount of chiseling is delineating where one end and the other starts. To top it all, I am working in a very confined space with asbestos wrapped pipes hanging all around me. Right now my wife is applying duct tape so when I come back the exposure will be minimal.
This is as bad as replacing the engine mounts on my W126 yesterday. One allen bolt was stripped while the other was not accessible as it hid behind the cross member. I got them bad boys out but I swear I will not do this again unless I have a lift.
Anyway, going back to the subject, the flanges seem salvageable if I don't destroy them in the process. Will see!
DP is offline
    high flo cats amgstyle R170 SLK-Class 1 05-19-2008 11:13 AM
    Thru Flo replacement Air Filter Hary Gahtoe C208/A208 CLK-Class 3 12-14-2006 08:01 AM
    New idle control valve Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 1 12-08-2006 10:53 PM
    What with FLO drivers Formoque C208/A208 CLK-Class 2 05-10-2006 04:47 PM
    Happy Birthday G560 - FLO! EuroTruck G-Class 6 10-04-2005 09:42 AM
