Flo Control Valve - Page 3 - Mercedes-Benz Forum
post #21 of 43 (permalink) Old 12-20-2008, 08:55 PM
~BANNED~
Jakarta Expat's Avatar
Date registered: Aug 2006
Vehicle: PM me to Join the Expat Muslims for Obama Club........
Quoted: 4 Post(s)
Originally Posted by drewprof View Post
Dead birds or nests maybe.
Jayhawks perhaps...........
Jakarta Expat is offline
post #22 of 43 (permalink) Old 12-20-2008, 08:57 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
That's an endangered specie I might have to call the Department of Unnatural Resources for proper removal
DP is offline
post #23 of 43 (permalink) Old 12-20-2008, 09:36 PM
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Originally Posted by MBLR View Post
If you end up destroying the flanges no worry you can just get a pair of "Nut and Gromet" adapters for any size pipe from 1/2 inch all the way up to 4 inch.
as for the flow valves Bell & Gosset is your best bet.
Your system must be an old steam heat system converted to hydronics because all of the hydronics systems I have tinkered with have shut off valves before and after the tank.
^^^^^^^^^Listen to DA MAN.
mlfun is offline
post #24 of 43 (permalink) Old 12-20-2008, 09:38 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
What a friggin mess!
I am right now taking a break from this job. I went ahead and supposedly drained the system from water but I forgot about the expansion tank
When I finished cutting the last bolt on the flange I got drenched and basically turned the basement into a pool. Anyway, I just finished cleaning up and my next job is to drill out the bolts from the flanges. They did not want to come out or cooperate; one had its head fused to the flange as if the metals combined and no amount of chiseling is delineating where one end and the other starts. To top it all, I am working in a very confined space with asbestos wrapped pipes hanging all around me. Right now my wife is applying duct tape so when I come back the exposure will be minimal.
This is as bad as replacing the engine mounts on my W126 yesterday. One allen bolt was stripped while the other was not accessible as it hid behind the cross member. I got them bad boys out but I swear I will not do this again unless I have a lift.
Anyway, going back to the subject, the flanges seem salvageable if I don't destroy them in the process. Will see!
Letting wifie do the dirty work, aren't you ?
mlfun is offline
post #25 of 43 (permalink) Old 12-20-2008, 09:39 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
my wife right now is all wrapped up in a heavy blanket and she's got all the cats on top of her, so no poky poky tonight
Isn't it time to call in the pros who can do the job right ?
mlfun is offline
post #26 of 43 (permalink) Old 12-20-2008, 09:41 PM Thread Starter
DP
DP's Avatar
Him yeah; you no!
DP is offline
post #27 of 43 (permalink) Old 12-20-2008, 09:42 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Ooops... wrong plumber.
mlfun is offline
post #28 of 43 (permalink) Old 12-20-2008, 09:43 PM Thread Starter
DP
DP's Avatar
We all do our share of dirty work. I had spent three hours tearing up at the metal from weird angles using power tools and hand tools. If you have nothing positive to say please STFU unless you know something about pipe fittings
DP is offline
post #29 of 43 (permalink) Old 12-20-2008, 10:34 PM
Vehicle: 1999 ML320
Quoted: 311 Post(s)
Here's the manual and some links..
Good luck. My advice still stands, sounds like a job for a pro.
Multiple hydronic questions - DoItYourself.com Community Forums
Troubleshooting a Hot Water Boiler - Water Leakage Around Boiler
mlfun is offline
post #30 of 43 (permalink) Old 12-21-2008, 05:15 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1530 Post(s)
Were you not paying attention earlier?
YouTube - Nationwide step in time commercial
Quis custodiet ipsos custodes?
Digmenow is online now
    high flo cats amgstyle R170 SLK-Class 1 05-19-2008 11:13 AM
    Thru Flo replacement Air Filter Hary Gahtoe C208/A208 CLK-Class 3 12-14-2006 08:01 AM
    New idle control valve Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 1 12-08-2006 10:53 PM
    What with FLO drivers Formoque C208/A208 CLK-Class 2 05-10-2006 04:47 PM
    Happy Birthday G560 - FLO! EuroTruck G-Class 6 10-04-2005 09:42 AM
