W = V x A - Page 3 - Mercedes-Benz Forum
post #21 of 49 (permalink) Old 12-03-2008, 04:08 PM
~BANNED~
Date registered: Sep 2004
Vehicle: 2002 clk320
Originally Posted by dope View Post
Resistance is futile to the collective.
Thats the spirit man.
the clk man is offline
post #22 of 49 (permalink) Old 12-03-2008, 05:01 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
Are they this business?
DP is offline
post #23 of 49 (permalink) Old 12-03-2008, 05:11 PM
DP
DP's Avatar
or this?
DP is offline
post #24 of 49 (permalink) Old 12-03-2008, 05:13 PM
joelschneider's Avatar
Date registered: Mar 2008
Vehicle: 1999 E320 4 matic wagon
OK, 1st of all do not leave any incandescent light fixture on unattended for long periods of time. It is a fire hazard. The rating on the bulb is similar to the amount of heat it produces when it is burning. Would you turn on a 600 watt space heater and leave for the day?
Next, If all of your under cabinet lights were fed from one transformer it would draw 50 amps we have wired several low voltage track lights that we have had to run #6 wire to to feed them, rated for 60 amps. Everyone else here is correct watts is watts the voltage does not matter. The reason they use different voltages is to make it safer in some applications and cheaper in others. When installing some lighting systems, fixtures less then 48 volts, the wiring system changes, we can use exposed wires and terminals instead of junction boxes and conduit systems. When installing feeder panels and wiring large machines we increase the voltage to bring down the amperage so we can use smaller wire pipe breakers etc... it is a lot more cost effective for the consumer and easier on my back.
Now, to figure how much it would cost you to run it there is a formula for that.
Energy= Power x time
Or
E = (watts/1000)xtime
In this example your wattage is 600/1000 because power is billed in kilowatt hours times the amount of time you will be leaving them on we shall use 8 hours in this example
E=(600/1000) x8 which equals 4.8 kilowatts if your utility charges you .05/ kilowatt it will cost you $0.24 / 8 hours you leave them on.
You can use this formula to calculate any appliance based on usage/ and the power it consumes.
"Fat, Drunk and Stupid is no way to go through life."
joelschneider is offline
post #25 of 49 (permalink) Old 12-03-2008, 05:27 PM
DP
DP's Avatar
Here is a nice link with many questions answered for these kind of lights (Cabinet lights)
Frequently Asked Recessed Lighting Questions by W•A•C
DP is offline
post #26 of 49 (permalink) Old 12-03-2008, 06:01 PM Thread Starter
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 465 Post(s)
Well, people leave outdoor incandescent lights on all the time, right? And indoor ones for that matter. Although I am careful about the application, and I thank you for your post & information...
The undercabinet ones are the first kind; most of the recessed ceiling ones are the second kind; a fair number of fixtures have the GU10 which look like this:
Marsden is offline
post #27 of 49 (permalink) Old 12-03-2008, 06:04 PM
DP
DP's Avatar
The ones you are showing are 240V
DP is offline
post #28 of 49 (permalink) Old 12-03-2008, 06:07 PM Thread Starter
BenzWorld Elitist
Marsden's Avatar
Quoted: 465 Post(s)
LOL those are British.... they mess up everything
Marsden is offline
post #29 of 49 (permalink) Old 12-03-2008, 06:15 PM
DP
DP's Avatar
British? 240V is 240V I can assure you it's 240V in France
DP is offline
post #30 of 49 (permalink) Old 12-03-2008, 06:24 PM
Smackrattle's Avatar
Date registered: Nov 2005
Quoted: 394 Post(s)
Member countries of the European Union are presently striving to achieve a common mains standard.
From 1 January 2004 the mains supply should be 230V (-6%, +10%), 50 Hz (±1%). ie a range of 216.2 - 253V
This replaces the UK's former specification which was 240V ±6% (ie a range of 225.6 - 254.4V)
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is online now
