Economy Reading while in Gear but Stopped - Page 2 - Mercedes-Benz Forum
View Poll Results: Does your economy gauge indicate a reading while stopped and in gear?
Yes 1 100.00%
No 0 0%
Voters: 1. You may not vote on this poll
post #11 of 18 (permalink) Old 11-29-2008, 01:29 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1003 Post(s)
That doesn't sound familiar
DP is offline
post #12 of 18 (permalink) Old 11-29-2008, 03:12 PM
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 452 Post(s)
Drew you need to remove the Credit Default Swaps (CDS).
Don't bail them out; just remove them, lock stock & barrel.
They're gumming up the system & causing the stalling.
HTH..
Marsden is offline
post #13 of 18 (permalink) Old 11-29-2008, 03:39 PM
MBLR's Avatar
Date registered: Sep 2006
Vehicle: 2k SlK230 / 2KSlk320 / 2000 Toyota Tacoma, 95 Land Rover D90 (done) Now looking for a series IIA
If you get time take a picture of the engine compartment a close up of the air Mass meter area would help.
and full model number / engine number....
I got time since I am sitting here doing online customer support today althought there may be delay in responding if I am at the support computer and not this one.
Also do you have a hand operated vacuum pump?
if so you can check the Dieverter valve also called MTC or Shut off Valve and check the Thermo Vacuum valve operation too
MBLR is offline
post #14 of 18 (permalink) Old 11-29-2008, 03:53 PM
Surely A Large Human
Qubes's Avatar
Date registered: Jun 2006
Vehicle: '08 C219
Quoted: 537 Post(s)
What the hell is an economy gauge???
Qubes is offline
post #15 of 18 (permalink) Old 11-29-2008, 03:56 PM
MBLR's Avatar
Gauge tied to the economy switch that you flip and it shuts off the gas and the car stalls.... that way you great great fuel economy since the engine not running?
MBLR is offline
post #16 of 18 (permalink) Old 11-29-2008, 03:56 PM Thread Starter
DP
DP's Avatar
I wish I could but it's dark and getting cold. I will be going under the car tomorrow anyway because I have to pull the trans cable so I can remove the front instrument panel. I need to calibrate the speedometer.
DP is offline
post #17 of 18 (permalink) Old 11-29-2008, 03:57 PM Thread Starter
DP
DP's Avatar
Something that will be a permanet fixture at the White House for once.
DP is offline
post #18 of 18 (permalink) Old 11-29-2008, 06:47 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1471 Post(s)
Ha, I have an economy gauge in my dash cluster, but it's been converted to read out turbo boost pressure, rather than vacuum.
Zeitgeist is offline
    Top Gear/Fifth Gear Reviews of Mercedes-Benz AZ.Benz General Mercedes-Benz 14 07-10-2008 12:52 AM
    gear cables & gear knob fitted today tripod23 V-Class 1 11-21-2007 11:36 AM
    Gear select display/ stuck in 1st gear raybenz W163 M-Class 1 03-18-2007 07:35 PM
    Newbie:94 c220 car shakes when stopped in gear and now it stalls podolski W202 C-Class 5 11-18-2006 11:50 AM
    I need a little real-world data: tach reading in high gear... Thomas.Schumacher G-Class 15 06-21-2004 11:28 PM
