190E Stalls - Page 7 - Mercedes-Benz Forum
post #61 of 128 (permalink) Old 11-28-2008, 05:56 AM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 112 Post(s)
Send a message via AIM to edfreeman
Originally Posted by the clk man View Post
Now that the dumbfuck Drew has went to bed without sex from his obviously understanding wife, here is the answer to his question. The problem with the 190E, is the catalytic converter. Just replace it and the car will run fine.
Ahhh, the constipation theory. Might be worth a shot.
edfreeman is offline
post #62 of 128 (permalink) Old 11-28-2008, 06:36 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 226 Post(s)
Like the one you traded to yosey for those bitchin' wheels? Yeeehaw!
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is online now
post #63 of 128 (permalink) Old 11-28-2008, 07:16 AM
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
You may be right with the cat. Steph's Saturn ran like shit, I looked up the code when the check engine light came on and sure enough, time to replace that bad boy. It was a bitch getting the old one off, I had to cut off three of the bolts and drill it out, but once the new one was on it ran fine.
The other thing that came to mind is the fuel regulator, but I don't know if the 190's had one. I had a very similar problem in my 126 that a new fuel regulator solved.
gerkebi is offline
post #64 of 128 (permalink) Old 11-28-2008, 07:28 AM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1066 Post(s)
clkman man is full of kaka, I have a brand new cat converter in there thanks to GS unless he sent me a crappy one then you guys are just in a crapshoot mode.
I did wake up this morning with a bunch of pussies on top of me looking for warmth and comfort. They purred too
DP is offline
post #65 of 128 (permalink) Old 11-28-2008, 07:31 AM Thread Starter
DP
DP's Avatar
It has a fuel pressure regulator off of the fuel distributor. On my W126 when that one went out it actually leaked gasoline via the vacuum hose connected to the breather hose. The 190e has a similar configuration and the hose is dry. I have no way of telling if it's not working other than leaking or having a typical failure symptom of said device.
DP is offline
post #66 of 128 (permalink) Old 11-28-2008, 07:34 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1633 Post(s)
It's a pressure thang
The fuel regulator was a common source of problems for the early CIS cars (again, pressure related), but Drew's 201 has CIS-E, which has incorporated that feature into the fuel distributor. Harbor Freight has an inexpensive fuel injection test kit, which I believe has the appropriate fittings and switch valve for testing CIS injection pressures. I'm pretty sure it's a cheap knock-off of the Snap-On version I own.
Zeitgeist is offline
post #67 of 128 (permalink) Old 11-28-2008, 07:36 AM Thread Starter
DP
DP's Avatar
I am going to the junkyard and then to Harbor Freight today, those are on my agenda. Any suggestions what I should be cannibalizing from some junked 190E and what else I need to get from HF?
DP is offline
post #68 of 128 (permalink) Old 11-28-2008, 07:43 AM
Cruise Control
Zeitgeist's Avatar
If the price is right, you should consider grabbing the fuel injection ECU and fuel distributor. Also, a spare fuel pump and accumulator would be nice.
Have you replaced the coolant temp and O2 sensors, yet?
post #69 of 128 (permalink) Old 11-28-2008, 07:46 AM Thread Starter
DP
DP's Avatar
My fuel pump and O2 sensor are new. I haven't installed a new coolant temp but that's on my mind. I did however replace the fan clutch temp sensor a few days after I got the car and I managed to eliminate the overheating (no more than 100c) problem the previous owner had.
DP is offline
post #70 of 128 (permalink) Old 11-28-2008, 07:47 AM Thread Starter
DP
DP's Avatar
I will be on the lookout for the ecu and distributor but those could be a crapshoot at a junkyard you know
I will try to get the whole intake and related knickknacks from a car if I find one.
DP is offline
My 190E stalls if the temp is below -15 deg C Guest (MBNZ) W201 190-Class 5 01-19-2016 09:21 AM
86 190E stalls at startup m4411b W201 190-Class 3 10-09-2005 01:38 PM
190E stalls when cold ssanmor W201 190-Class 4 03-08-2005 09:57 PM
85 190E 2.3 stalls jaguarnaut W201 190-Class 5 08-30-2004 08:49 PM
190E splutters and stalls Guest (MBNZ) W201 190-Class 16 11-18-2003 02:43 AM
